06-30-2008, 09:13 AM | #1 |
c notch with stock bed floor?
doing an 86 square trying to come up with an idea to retain my stock floor. i need to make a notch that will give me alot and be riged. i still need to tow, but its gotta be bagged too lol! do you guys have any ideas?
06-30-2008, 08:42 PM | #2 |
Re: c notch with stock bed floor?
If it's a large c-notch you will need to either raise the bed floor or add a notch cover.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
07-24-2008, 09:22 PM | #3 |
Junior Member
Notch cover
going to sell this one...looking for a SWB project next. |
07-24-2008, 09:51 PM | #4 |
One day...
Raise the bed floor for me.. but i like the straight wood bed look.
07-24-2008, 11:14 PM | #5 |
You're going to have to make a compromise to get low and tow... I would raise the bed floor.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
07-25-2008, 12:16 AM | #6 |
Happy to be here
That's exactly why my 77 sits like it does. You can't get much lower with a stock bed, and I refused to cut it up. Your going to have to find a compromise somewhere.
07-25-2008, 01:06 AM | #7 |
3DrDwn--the 'burb not the band
on my 92 I rasied the floor 4" but did it in a way that appeared stock just shallower. I cut it in between the rolled lines and then trimmed and adjusted the cut so the lines lined back up tricking the eye into seeing a stock bed. At the time I was hauling a drag bike and couldn't have the "hump" notch cover. other than the "step" at the gate with it folded down It worked as good as a stock floor for my needs.
Josh PS decided to add some pics I know it's not a 67-72 but the fundamental is sound: floor raised but no inner fenders yet: two with the fenders trimmed back in, added a piece across the top of the fenders to account for bed wall sloping away as it went up: can't find any after it was repainted but it's tough to tell where it was modded unless you know the stock lines. It is pretty obvious that it's shallower though
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 Last edited by RunninLo; 07-25-2008 at 01:16 AM. Reason: adding pics |
07-25-2008, 12:00 PM | #8 |
07-25-2008, 06:25 PM | #9 |
One day...
Runninlo,
That looks good man, its funny to see how many people don't notice that the floor is raised with the tailgate shut Last edited by scotts62; 07-25-2008 at 09:38 PM. |
07-27-2008, 12:22 AM | #10 |
Happy to be here
It's bagged. Let me clarify that I could go about an 1 lower, but I wanted it to roll when aired out.
07-27-2008, 12:24 AM | #11 |
Happy to be here
Contact Frank (7t7) and get pics of his bed. He raised it up like RunninLo has pictured.
RunninLo your avatar cracked me up.
07-27-2008, 01:05 AM | #12 |
I'm hoping to be doing my squarebody similarly once I get the susp. pieced together and will chronicle it in the build page when that is started.
N2 I had my burb as my avatar but I also have a pic in profile. decided I wanted a gif that did something. I have one that is an orange kitten scratching turntables but it was about 300kb and too big to be used here. this one works for me and meets the site's req. fitting too since I'm almost as big a cat guy as a truck guy. Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
07-30-2008, 10:31 AM | #13 |
