Old 06-30-2008, 03:21 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
boggin at full throttle
lastnight i was out gouging on by truck and i noticed that when i floor it, the engine would bog down very badly. this wasnt just a stumble. the truck would not overcome the bog at full throttle. it would bog as long as i had my foot down. what might cause this? i did just put a new vacuum advance on the distributor and set the timing to 12 degrees.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 06-30-2008, 03:23 PM   #2
lowriden58
lowriden58's Avatar
Re: boggin at full throttle
sounds like your advance isnt opening or maybe you have a fuel issue
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 06-30-2008, 03:34 PM   #3
Billla
Billla's Avatar
Timing, then carb.
Is the vacuum advance adjustable, and if so is it adjusted?
Have you set your mechanical advance?
If the timing is right, then we start looking at secondary opening - what kind of carb is it and what's it's condition (new, recently overhauled, never touched, etc.)?
Billla is offline   Reply With Quote
Old 06-30-2008, 03:51 PM   #4
crm318
crm318's Avatar
the carb is a rebuilt qjet. im not sure if the vacuum advance is adjustable. how could i tell? how would i set my mechanical advance?
1972 Cheyenne
Old 06-30-2008, 03:59 PM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
I'd check the fuel filter as well. You can tell if the vac adv, is adjustable by looking at the area right next to where the hose attaches. If that area is smooth it's NOT adjustable. If it is five (or 6?)sided,it is adj.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 06-30-2008, 04:40 PM   #6
crm318
crm318's Avatar
it is smooth and i assume non-adjustable. i have a clear fuel filter and there doesnt seem to be any debris in it, but ill check. the truck runs fine at all speeds accept full throttle.
1972 Cheyenne
Old 06-30-2008, 05:22 PM   #7
d10s69c10
Built 4 Speed
d10s69c10's Avatar
a Quadrajet has a filter right in the carburator at the fuel line. i had the same thing happen to me i just removed it and the spring and my truck ran like a raped ape.
"i couldent blow thru it to save my life"
almost feels like vapor lock?
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 06-30-2008, 05:32 PM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
Was having a similar problem with my 70 K5 when I finally got it running with a rebuilt motor. I changed out the fuel filter in the quadrajet and it was a touch better but still having a bog at full throttle. It was also vapor locking pretty bad.
Replaced the mechanical fuel pump and the bog and vapor locking problems were gone!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-30-2008, 07:18 PM   #9
haysonj
haysonj's Avatar
there should not be any vacuum advance at full throttle so I doubt the problem is in the vacuum unit. You could cap it off and it will only affect cruise and idle. I would tend to think it is fuel related. may have to large of secondaries or make sure that the secondaries are fully opening when you mash it from inside the truck. Have a friend look while the truck is not running.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 06-30-2008, 07:38 PM   #10
Billla
Billla's Avatar
WorkinLonghorn nailed the adjustable vacuum advance question - the mechanical advance question is answered in my timing FAQ linked in my sig.
The vacuum advance for the Q-jet can be adjusted - it's called an Air Valve. Once the timing is right we can look at that.
Definitely agree making sure the in-carb filter is removed if you have an external filter!
Old 07-01-2008, 04:23 PM   #11
crm318
crm318's Avatar
the filter in the carb is removed. probably about 2 weeks ago i got down on it and it roasted the tires off. i dont know how it could come out of adjustment in that amount of time. as far as the vapor lock issue, the truck acts like this reguardless of what temp the motor is or if i just started it or have been running it all day. i assume vapor lock is caused by heat. ill give the dist. and the carb a look over.
1972 Cheyenne
Old 07-01-2008, 04:31 PM   #12
telly
telly's Avatar
I just finished fixing a similar problem with my Monojet and inline 6 250ci.
The things I did -
1) Replaced the fouled spark plugs
2) Rebuilt the carb (although it might not have been necessary - should have done this last)
3) Attached the vacuum advance to the proper port (PO had the vacuum advance port from the carb running to the charcoal cannister)
4) Reset the timing and idle speeds
Finally this morning the truck is accelerating like it should.
Hope this is helpful - don't know if there is carry-over from my truck ('70 C10) to yours.
Good luck. I'll be watching your progress.
telly is offline   Reply With Quote
Old 07-01-2008, 06:06 PM   #13
crm318
crm318's Avatar
i just tore back in my distributor and i noticed that the new vac advance was very stiff. i took it off and sprayed some pb blaster lubricant in it ans now it moves more freely. we will see how that works.
1972 Cheyenne
Old 09-25-2008, 09:41 PM   #14
welch_41
I'm curious if spraying lub in the vac adv. cured your problem. I'm having a similar issue with my 66 C10/250. The carb has been rebuilt and timing set to 4 deg BTDC. When I first bought the truck it had a Holley carb on it but I couldn't find a rebuild kit for it so I picked up a reman Rochester Monojet. Thats when my problem started. From reading previous post, does an inline fuel filter make that much of a difference over the filter in the carb? Thanks for any help.
welch_41 is offline   Reply With Quote
Old 09-26-2008, 03:37 PM   #15
OrangeCrush1970
OrangeCrush1970's Avatar
raped ape is good, I might have to try that one
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline   Reply With Quote
