Old 06-30-2008, 04:54 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Need Help with Vaccum Can
My new cam left me with very little vaccum. I've heard of hooking up an additional can to get more vaccum and make the brakes work, Any help would be appreciated.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 06-30-2008, 06:44 PM   #2
haysonj
haysonj's Avatar
Re: Need Help with Vaccum Can
Get a vacuum pump that operates off 12 volts
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 06-30-2008, 06:47 PM   #3
neonlarry
neonlarry's Avatar
http://www.jegs.com/webapp/wcs/store...acuum+canister
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-30-2008, 07:36 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
following the link that larry posted;
That's the one I had when i was over cammed for power brakes. Run manifold vac to the brass nipple, then from the other port, to the booster.
Old 06-30-2008, 07:54 PM   #5
LONGHAIR
I think it goes the other way Andy. The black fitting is the "check valve". The vacuum is applied to there. It keeps the vacuum in, so it doesn't bleed-off when you shut the engine off, and it keeps back-fires out. Then the brass fitting goes on up to the check-valve on the booster.
LONGHAIR is offline   Reply With Quote
Old 06-30-2008, 08:07 PM   #6
Longhorn Man
dislexia is a hctib. You are 100% right.
Hey, it was 10 years ago.
Old 06-30-2008, 08:43 PM   #7
LONGHAIR
You can't type LOL backward..........OAML
Old 06-30-2008, 11:52 PM   #8
1970 CST Short Wide
Senior Moment
How simple, Thanks
Pittsburg Ca
94565
Old 06-30-2008, 11:54 PM   #9
1970 CST Short Wide
Senior Moment
How many inches are best to run brakes? I did a check and have ~12
Pittsburg Ca
94565
Old 07-01-2008, 08:53 AM   #10
1970 CST Short Wide
Senior Moment
ttt
Pittsburg Ca
94565
