bought a old truck
rear brake lines rotted, any way to plug those lines so only the front work? just so i can move it around the house..
Old Skool Club
![]() Join Date: Jun 2001
Re: bought a old truck
I'd say take them loose from the rear wheel cylinders and find a plug that would fit it, and install it.
Someone else might say to take the brake line loose and bend/crimp it shut with enough force to contain the brake fluid. Principles of hydraulics says you can't compress a liquid. With enough pressure in that line, it will leak. Take the line loose at the master cylinder and plug it there. With old brake fluid in the lines, they will absorb moisture and will have to be replaced.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
as cheap and easy it is to buy new lines and bend them to fit, if it was my project, i wouldnt waste my time or effort doing a temperary hack job. thats just me
72 chevy 3\4 ton 4 speed 4x4 84 1\2 ton 4x4 (gone but not forgotten, thanks for the memories) 1999 suburban 4x4 1982 chevrolet S-10 V-8 (Thanks uncle EARL) |
I think it should use a dual master cylinder if its 67 or newer, so only the fronts should work now... Of course, they may not work either.
I agree with trailwart above... |
Old Skool Club
I agree with you both; I was just answering his question.
You never can tell what you'll find when you go to work on something that someone else has "fixed" in a pinch/bind/hurry.
laying low
![]() Join Date: Mar 2001
It is a dual bowl master cylinder system where the front brakes are separate from the rear brakes. When fluid pressure is lost on one end of the vehicle the other ends' brakes still work. A safety designed into them. If your rear lines have rusted out the rear brakes are already disabled putting all of the braking duty on the front ones. The rear lines leaking should not stop the front ones from working so no line plugging is needed. Do I have to mention you don't want to drive it on the street like this?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver 'primer is finer' Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Old Skool Club
Jim, I just looked at the original post and he's never said what he bought. Could be he's as old as we are, and an "old" truck is truly OLD!!! If I can't remember when it was new, it's old.
![]() Then again, he's in Maine. Based on my observations in Rhode Island at the kids' house, anything that still runs that was built before 1980, is old.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 07-03-2008 at 12:03 PM. |
its a 88, i bought it and though i could use it around the house but its far to gone, the body is badd, needs tires, windows broke.. i figure im just gona rebuild the 350 for my c10..
| Bookmarks |
