its all about the +6 inches
Removed from big block 72 burb, C/20
Has the 9/16ths studs (all 16 there) coil spring/trailing arm ready 3.54 gears posi/locker/limited slip (still works) brakes work but are a bit grabby (uninspected, but no metal to metal) Complete from drum to drum even has good brake lines Makes no howling or other noises READY TO INSTALL AND RUN AS IS (brake inspection recomended) Local pick up only $200 or REASONABLE offer No PM's taken, respond here only. I can get numbers as requested, or photos Best factory offered gear for C/20 trucks. Lower your cruise RPM's today! Save gas! Will fit any and all coil spring trucks Some driveline mods may be required unless you are replacing a Dana Panhard bar replacement may be needed too. |
Re: DANA 3.54 rear for sale
oh yeah.... NO pay pal
NO checks Since this is a pick up item, it is cash or money order (cash prefered) only. |
Boy, wish you were closer. been looking for this gear and posi combined. I would really want just the guts, but your deal is good enough to buy it all, but way to far away. Good luck with sale.
The ONLY way to go. ![]() 1972 C20 Custom Deluxe: Rebuilt 402 hopped up a bit, th400 with shift kit, Dana 60(wanna have posi), New solid, no cancer, cab. B & M Starshifter floor shifter.
If no one bites, I will consider sending you the guts, shipped on your dime.
Would the guts work in a c10 rear axel case.
My Rides 1969 Mustang gt coupe 1971 Chevy Cheyenne 1986 Iroc camaro 1986 K10 Short Bed 1987 Iroc Camaro 1990 rs Camaro 1992 350 ss truck 1998 Honda Civic 2005 Ram 2500 Cummins My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=279831 |
Waah Waah
I'd love to bite on the whole thing but can't do the 2000 mile round trip!
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater. |
Yeah I would like that to. But the closest I will get is Nevada.
Mark 67 c20 custom camper 55 Olds 2dr hardtop 96 mustang 11 dodge nitro |
49M... if you have a dana60 1/2 ton rear, then yeah, but I've only heard of that once.
daily bump...
Cummon, someone around here NEEDS this. |
so all the 3/4 ton guys are happy with there 4.10 or 4.57 gears and MPG/RPMs?
Make reasonable offer. |
![]() Join Date: Nov 2006
IF ITS GOT A POWER LOCK I,d be interested in it my friend.
bob 1 423 384 8938
I BELIEVE IN JOHN 3:16 |
![]() Where is your friend located.... or do you have a way of getting this there? Like I said, I can't deliver. The longhorn can't be trusted on the open road, and there's no way this is goin in the back of the burb if/when it goes that direction (new carpet and seriously limited payload now that it's slamed) I'm willing if you have the ability. |
#13 |
morning bump
#14 |
Middle-aged Curmudgeon
I'll take it.
I just bought a '72 C20 that needs it for a more-or-less stock restoration. |
#15 |
you have a way to get it in central ohio?
#16 |
Yes.
Wish I'd have seen this thread sooner but have already made plans for the holiday weekend. I'm just now getting ready to bug outta town for three days to visit some in-laws and won't be close to a computer. Glad you responded back when you did. Next good chance I have to pick it up is two weekends from now, July 19th & 20th. I live in the Kansas City metro, and can make a flyin' weekend trip to your area. In the meantime, I'd be glad to send payment to hold it until then. Would that work?? |
#17 |
PM sent
#18 |
Consider this sold... if BCOWANWHEELS backs out, then lugnut has it.
#19 |
all i really wanted was the power lock & ring & pinion gears. if lugnut needs it andy by all means let him have it. thanks for being so thoughtful though. your a honest guy. if it dont work with lugnut i,ll be a backup......
bob
#20 |
thanks for the responce there bob...
As of now, it's considered sold to lugnut. If anything happens, I'll lte bob know, and relist it after that if need be. Thanks. |
| Bookmarks |
