Old 07-01-2008, 03:12 AM   #1
berencam
berencam's Avatar
new engine checklist
getting closer to the fire up day. Anyone have a checklist of stuff that needs to be checked and double checked. (getting kinda paranoid, dont want all my hard work to go down the drain)
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 07-01-2008, 08:05 AM   #2
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
Re: new engine checklist
make sure you prime the oil pump!
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 07-01-2008, 08:15 AM   #3
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Question Re: new engine checklist
Sorry for the Jack but I have a question How do you prime the Oil Pump? My motor has been sitting in the Garage for about 5 months now it was running fine when I pulled her out for painting I will be putting her back in I am hoping this month Will I also need to Prime besides adding fresh Oil & Coolant? Thanks....By the way Nice Motor berencam Looking good!
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 07-01-2008, 08:40 AM   #4
ksjh1316
ksjh1316's Avatar
I don't have anything to add to the question except man that looks nice good job so far.
ksjh1316 is offline   Reply With Quote
Old 07-01-2008, 09:00 AM   #5
haysonj
haysonj's Avatar
Best way is to pull the dist and put a electric drill on the pump shaft. they make a tool for this but you can make one with an old screwdriver and socket.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 07-01-2008, 09:05 AM   #6
haysonj
haysonj's Avatar
If you used lots of assembly lube you have no problem adjust valves cold fire the motor set timing and run at 2000 RPM for 20 min to break in cam. Good luck always nervous time on a new motor.
Old 07-01-2008, 09:11 AM   #7
Billla
Billla's Avatar
I'll start - and then we can tune this post based on other's feedback. Hopefully you adjusted the valves on the stand - WAY easier
  1. Adjust valves if not adjusted on the stand
  2. Secure engine; motor mounts, towers, bellhousing bolts.
  3. Secure exhaust.
  4. Secure drivetrain (torque converter, etc.)
  5. Check accessory drive; belts adjusted, etc.
  6. Ensure engine is watertight; sending unit, hoses, etc.
  7. Fill engine with water (I always use just water for break-in)
  8. Ensure engine is oil tight - oil pressure sender/line, any plugs, fuel pump rod hole, etc.
  9. Secure oil filter and fill engine with oil. Check dipstick markings. Add 1 pt break-in lube (EOS or similar)
  10. Check starter operation with a brief "bump"; ensure grounding straps are in place. Look for any loose electrical connections.
  11. Ready the distributor - #1 marked on distributor body, cap/wires ready, etc.
  12. Pre-oil engine thoroughly, rotating engine 90 degrees after oil is seen in rockers until 1 full revolution.
  13. Set engine to 10-14 degrees BTDC compression #1
  14. Install sparkplugs
  15. Ensure no oil on headers or exhaust. Have a fire extinguisher
  16. Drop distributor so rotor points at #1. Bump until drops into oil pump as needed.
  17. Install cap and wires, checking carefully
  18. Fill carb bowl through bowl vent if possible
  19. Crank and start
  20. Cam break-in as recommended by cam mfgr.
What'd I miss?
Billla is offline   Reply With Quote
Old 07-01-2008, 09:13 AM   #8
Billla
Billla's Avatar
This type of tool is what you want
http://store.summitracing.com/partde...0&autoview=sku
Old 07-01-2008, 09:27 AM   #9
truckdude239
truckdude239's Avatar
make sure your oil pug is tight use a good filter puraloter or a delco are my perfereed bands.
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 07-01-2008, 09:43 AM   #10
Police22
Police22's Avatar
I did this when I rebuilt the motor in my boat.. It worked good.. as long as you get/find one long enough...
1970 C10 1/2 Ton Longbed with 70' 307ci TH350 SOLD
Just getting it back to a daily driver for now.
Then will slowly work on getting the project going.
Police22 is offline   Reply With Quote
Old 07-01-2008, 10:10 AM   #11
jorgensensc
jorgensensc's Avatar
Make sure you have good ground straps attached so you get full power to your dizzy. Wipe up any oil spillage on engine or header/ manifolds. (My buddy had wrapped headers and he spilled oil on them. During cam break in the wrap caught on fire and we had to shut it down. Burned up alot of wiring and the dry chem extinguisher made quite the mess, especially since he had the air cleaner off, DOH.) I like to use Wix (or Napa gold same thing) oil filters, but it is a preference thing.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 07-01-2008, 10:12 AM   #12
HavinSomeFun
you can also dump a little oil in each cylinder, make sure all the plugs are removed and crank it over until you have oil preasure. With no resistance on the engine and only spinning it over the pump will be primed and you will be good to go.
Old 07-01-2008, 10:17 AM   #13
Billla
Billla's Avatar
Shawn
Good notes!
Old 07-01-2008, 10:20 AM   #14
Billla
Billla's Avatar
IMHO, this is really not the right approach. This much cranking wipes the cam lube off, and putting oil in the cylinders just makes a mess and delays start. The bores should be plenty wet with assembly lube.
Buy the right tool for the job for $20!
