Old 07-01-2008, 03:32 PM   #1
VanceH
Loving the Jimmster
VanceH's Avatar
questions about lowering a 67
This is in referance to the post
http://67-72chevytrucks.com/vboard/s...d.php?t=196457 Lowering Blocks 101
I could not reply to that post so here it goes.
Can you use a larger than 2 inch block?
Can you use a block and cut the rear springs as well?
I am wanting to lower the front about 2 inches and the back about 5-6 so that it will be level.
Vance
VanceH is offline   Reply With Quote
Old 07-01-2008, 05:34 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: questions about lowering a 67
Vance,just for reference check a few of the threads.Most members here do a 2/4 or a 2 1/2 /4 drop.This seems to get everything level.If you go more than 4 I think the front will set higher than the rear.
On lowering blocks I think 2 in is about as much as you want to go.Remember that for every inch of drop you also lose that in scrub or distance from the lowest suspension point to the ground.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-01-2008, 05:41 PM   #3
VanceH
Loving the Jimmster
VanceH's Avatar
Thanks man, i have alot to learn!!!!! I am almost done with the new shop so i am just iching to get started on the truck. I just hate how the rear end is so high on my old truck. thanks again
vance
Old 07-01-2008, 05:43 PM   #4
streetstar
streetstar's Avatar
if you have rear springs --- you just get shorter springs -- you don't need to be concerned about blocks
If you go as low as 4 or 5" - a C-notch would probably be good
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 07-01-2008, 05:55 PM   #5
SCOTI
SCOTI's Avatar
One thing to consider is that blocks allow drop w/o affecting the overall shock travel. The ideal scenario for a 6" drop would combine dropped springs w/blocks & shock relocators as this set-up allows running off the shelf shocks.
2" blocks are about the max w/o becoming hazardous w/a 15" wheel combination. If larger diameter wheels are utilized, a bigger block can be used because the scrub line is changed. The caveat here is that the trailing arms start hanging down farther from the rear-end & thus become much more visible which just doesn't look right.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
