Old 07-01-2008, 05:26 PM   #1
CCCC
CCCC's Avatar
Brake Vac Booster -Disc Brake C10 and C20
I need a new booster unit for a BB C20 (front disc brakes) and a seemingly knowledgeable fellow recently told me that the two types seen on 71 and 72 C10s and C20s are interchageable. It has appeared to me that the C10 vac tank unit is a bit thinner and slopes a bit from front to back on the perimeter, and that the C20 unit is a bit thicker and straight from front to back on its edge. Is this the case? And, are these two units interchangeable for use on either the C10 or C20? Thanks in advance for any insights. CCCC
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 07-01-2008, 06:07 PM   #2
john
member #16
john's Avatar
Re: Brake Vac Booster -Disc Brake C10 and C20
The c-10 booster is single diaphragm, and the c-20 is double diaphragm. I would stick with the double for a c-20.
john is offline   Reply With Quote
Old 07-01-2008, 11:17 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
agreed.
They CAN be swapped out, but why downgrade your brakes?
Old 07-02-2008, 12:10 AM   #4
CCCC
CCCC's Avatar
Thanks guys, for the usual quick and informative reply. After measuring I could see that either should fit, but knew there had to be a reason for the difference in shape/size. Of course, I will stay with the double diaphragm unit.
CCCC
