Old 07-01-2008, 08:06 PM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
What rear setup ???
ok guys, Im having a hard time filtering through all the different set ups I could run on the rear of my 77
It was no big deal on my 67, as all I really had to do was swap the springs for bags, but beings how the 77 is a leaf sprung truck I just dont really know what set up to run
Parallel 4, triangulated 4, canti setup, watts link, panhard bar... What I just dont know
So I guess, give me your input on which rear set up works best or the advantages & disadvantages of each
I want to roll LOW, I doubt I have anything bigger than 18's on it, but I do like some rubber around my wheels
Also not a big fan of notches & will either Z, Back half, or build a new frame for it
Travel isnt the biggest importance either, I would rather it ride SMOOTH
So I guess I also would like to know about bag positions, & what would give the best of both worlds
And while on the subject of bags, I really dont know which ones to run on it
I really dont have any plans of hauling anything, but I may throw a 4-wheeler in the bed
I have a pair of RE-7's & a pair of F-9000's & really dont know which would be better for this aplication
Now after all that, Im gonna be picky bout what info I take in
Im not gonna buy anybodys kit or bolt on thing, so dont tell me to go buy so N so's whatever
Not looking for any over stuffed opinions either, just what you have done & what you would do different
Sorry if I come across a lil rude or too picky, just dont want a big debate going on in my thread
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 07-02-2008, 06:36 AM   #2
HotRodYJ
HotRodYJ's Avatar
Re: What rear setup ???
I plan to Z the back of my frame to get the drop I need. I would like to build an all new back half, but it is less costly to Z what is already there. Actually instead of a true Z, I'm toying with the idea of cutting and mittering out a little where the factory bends are for the frame kick up. By mittering out a little more at each bend, I can tweak the factory frame to kick up higher. Then of course weld, fish plate (the inside out of sight) then box this section of frame where the cuts are made for strength. Should end up with a much more factory kind of look. Make people wonder what exactly was done.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 07-02-2008, 09:28 AM   #3
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I have thought of this & like the idea
Just the same as you, I'd prolly rather Z it than back half it
Anybody else ???
Sinister
Killer
Old 07-03-2008, 12:07 AM   #4
SCOTI
SCOTI's Avatar
How low are you wanting to go?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-03-2008, 01:02 AM   #5
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I'd say probably something like 5" to rocker at ride height... That is what the drop member is capable of with 3" drop spindles correct ???
Im not exactly sure on tire height either, as Im not sure what im going to wind up running... but it most likely wont be over an 18" wheel, so I guess somewhere around a 27" to a 29" tall tire ???
Sinister
Killer
Old 07-04-2008, 04:18 AM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Ok, just so I can narrow it down some Ima make a guess as to what Im leaning towards
Lets just say that Im going to run a 28" tall tire in the rear & Im going to do stepped Z or whatever & raise my frame up behind my cab, do a bed floor raise & what not
What is the best set up to hold my rear axle in place, whats the best bag placement & which bags are better for this application ???
Matt
Sinister
Killer
Old 07-04-2008, 11:55 AM   #7
SCOTI
SCOTI's Avatar
I measured my truck w/a static drop for reference. It has 3" spindles w/cut coils up front & flip-kit w/drop shackles out back. Behind the front wheel @ the rocker 'pinch' = 6.75 (27.7" tire). In front of the rear wheel @ the rocker 'pinch' = 8" (29" tire).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-04-2008, 12:03 PM   #8
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Thats sounds like a pretty nice ride height, where can I get some more pics of your truck ???
Sinister
Killer
Old 07-04-2008, 07:12 PM   #9
SCOTI
SCOTI's Avatar
Best one I have (someone else took the pic @ TX HeatWave in 03).....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-04-2008, 07:35 PM   #10
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Love your truck bro
I would think that would be a good ride height, but I would definitely want it to lay frame at dump
I already know what Im doing up front, & I know what i want to do with the frame in the rear, just dont know what suspension is the best for the rear
Sinister
Killer
Old 07-04-2008, 11:16 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
I'm confused. You say you don't want a kit. Does that mean your going to buy the parts and build it yourself, or you just don't want a bolt in kit?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-04-2008, 11:52 PM   #12
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I dont want to buy a kit, bolt on or otherwise
I will build it, if I have to buy a few parts here & there thats just a part of it
But Im not going to go buy KP's rear canti setup or Thorbecke Bros 4-link, see what Im saying
Im not going to have someone ask me what rear suspension do you have & me tell them I bought SO n So's kit & installed it... Plus I dont have the money for a that stuff
Sinister
Killer
Old 07-05-2008, 12:08 AM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Ok, I'm with you. I think most will agree that a 4 link is the best way to go. Then your going to have to decide how you want to locate the rear. Do prefer a watt's link or a panhard bar?
Articles-
"Refining Sierra"
Old 07-05-2008, 05:41 PM   #14
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Well Im leaning towards a Watts link
Now what do yall think about a parallel trailing arm set up instead of a 4 link ???
I would think that with a watts link that it would stay centered just fine & then the track bars would be similar to the 67-72s but instead of running at an angle I would run them outside the frame & attach them to the spring perches of my axle
Sinister
Killer
Old 07-06-2008, 12:09 AM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Doesn't sound stable to me. The arms need to be triangulated to control the sway, even with the watts link. Personally I don't like the clutter of a watts link. I prefer a 4 link with a panhard.
Thanks to KP Components for their quality pics-
Articles-
"Refining Sierra"
Old 07-06-2008, 01:06 AM   #16
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
How is the 4-link any more stable ???
Here is a pic of what Im talking about (Im pretty sure this us a board members truck)
Sinister
Killer
