Old 07-01-2008, 10:06 PM   #1
GMC65Guy
Will these wheels fit?
I'm looking for some aftermarket wheels, Will these fit a 6 bolt fenderside?
Bolt Pattern Offset
15x6 6x139.7 0.00
GMC65Guy is offline   Reply With Quote
Old 07-02-2008, 01:44 AM   #2
blackedoutharley
Re: Will these wheels fit?
That sounds like the specs for the stock, oem wheel and the only thing I can think of that would make them not fit is if the center bore hole is not large enough to clear the hubs.
Only 'disadvantage' to the 15"X6" is that it is pretty narrow and finding tires that are tall enough that are not too wide for the wheels will be tough; especially in a radial.
Are you going for the stock look?
If so I would recommend a 7.00X15 tire.
They are bias ply, just like the originals, and will work fine. You could find the original size from places like Coker Tire but the cost will much greater than the 7.00X15 which should be available at your local tire shop and is real close to the original size tire.
P.S. who makes an aftermarket wheel in 15X6 in a 6 lug pattern? And what style/construction is it?
blackedoutharley is offline   Reply With Quote
Old 07-02-2008, 01:56 PM   #3
64c20crewcab
64c20crewcab's Avatar
15x6 - 6 lug steel wheels are available from WheelVintiques.com or StocktonWheel.com
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline   Reply With Quote
Old 07-03-2008, 03:31 AM   #4
blackedoutharley
Yeah I know about them (both are customers of mine) I just don't consider a steel wheel (stock style) as aftermarket...
Old 07-03-2008, 08:15 AM   #5
GMC65Guy
These are what Im going to go with
http://www.hotrodhanks.com/products/...roductID_/4426
powdercoated red
Old 07-04-2008, 03:12 AM   #6
blackedoutharley
Are you running the 6" wide wheel on front and rear?
Old 07-04-2008, 09:58 AM   #7
GMC65Guy
Right now or when i get new wheels? Right now i have the stockers in front and some wider ones in the rear.... when i buy those I planned on getting them for all 4's
Is there something wrong with running those wheels? Don't people with "phycho billy,rocka billy" trucks use those all the time?
Old 07-04-2008, 10:52 AM   #8
64c20crewcab
nuttin wrong with them at all. soem run the stock wheels. i've ran rallye wheels painted black and caps on my 91 gmc suburban on bfg's and same wheels on my last c10 with bullet caps on www's. looked just fine. bottom line is to run with what ya like. it's yer truck.
Y2K INDN Chief
