Old 11-10-2002, 09:03 PM   #1
pphatbasstard
pphatbasstard's Avatar
Squeaking
I have 67 1/2 ton and it is squeaking quite a lot when i go over bumps and when i turn. What part of the suspenion do u think is doing this? thanks
pphatbasstard is offline   Reply With Quote
Old 11-10-2002, 10:27 PM   #2
crazy longhorn
Fabricate till you "puke"
my guess would be A arm bushings or ball joints. you might shoot a little grease in all the points in the front suspension......if any of the zerks wont take grease, you may have to remove the zerk & replace it (also clean the hole as best you can with a small pick. good luck
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-11-2002, 02:09 AM   #3
Alexis
Member since 2000
Alexis's Avatar
could be your shocks. or a broken rivet on a crossmember
Alexis is offline   Reply With Quote
Old 11-12-2002, 01:39 PM   #4
matt67350
matt67350's Avatar
It's the upper a-arm bushings. WD-40 until you get them replaced
Good Luck,
Matthew
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 11-12-2002, 01:39 PM   #5
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
My guess would be A-arm bushings as well.
Bounce the front end up and down with the hood open and you should be able to hear where its coming from.
Denny
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 11-12-2002, 10:51 PM   #6
chevykid04
4 speed, hurst shiftin
chevykid04's Avatar
hey lets start a squeeky a- arm bushing club! haha i just put new zerks in , just gotta use the grease gun at work cus mines broken
Shane
1970 Chevy C10
chevykid04 is offline   Reply With Quote
Old 11-13-2002, 05:36 AM   #7
Brad
Out of the carpool lane.
Brad's Avatar
Might also want to grease the panhard rod in the rear...I've got poly bushings and this quieted it down.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 11-14-2002, 02:50 AM   #8
K5KRAZIE
Its a long shot but check your frame behind the steering box for cracks.
TRUCKS
'72 K5
'06 mega dually
K5KRAZIE is offline   Reply With Quote
Old 12-12-2002, 09:54 PM   #9
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
Make shure your rear coil springs are tight. the previous owner of my truck used a wheelbearing and a pice of plate for a lower spring cup it squeaked pretty bad. I cant understand why.
GMC JUNKIE TOO is offline   Reply With Quote
