Old 07-02-2008, 09:26 AM   #1
bguild
bguild's Avatar
Air Ride Driveshaft Ques..
I have a 1968 SWB Truck.. I have it down to the frame and i plan to put a step notch in the rear very soon. I am close to being able to bolt the cab back on but I have some questions regarding the driveshaft. i currently plan to run 22's in the rear and 20's up front and put some bags all the way around. I know ideally I should put a double driveshaft or a 2-piece whatever you call them. I want to see how low i can go with keeping the stock driveshaft and just modifying the current crossmember. If I put a new driveshaft loop in how much taller do I need to go? I dont mind tunnel the floor some if i need to but would rather not. I know i could buy a cpp crossmember for around 200 bucks but since i will be welding stuff in the rear I figure i would save some money and just weld in a new driveshaft loop.
Any help would be appreciated--pictures-- concerns withdoing it this way-- really anything because i am new to the air ride scene.
Thanks in advance.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline   Reply With Quote
Old 07-03-2008, 04:02 PM   #2
bguild
bguild's Avatar
Re: Air Ride Driveshaft Ques..
So nobody can help me here?? I know there are guys on the board that have done this.
If you cant help me with modifying mine can you give me some info on doing a split driveshaft?
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 07-03-2008, 04:09 PM   #3
PBFAB.COM
PBFAB.COM's Avatar
How low are you wanting to go? Lay frame? an inch or two from the ground? Also, what height tire do you plan on running?
If you go one piece, there's some pretty extensive cab floor/back wall trimming to do.
Also, if you need some good information on split driveshafts and how to set them up, try this link: http://www.airridetalk.com/articles/...nt-enigma.html
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-03-2008, 04:52 PM   #4
bguild
bguild's Avatar
I think I plan to run a 265/35/22 tire.. 29.3 inches.. I dont really care about laying frame but I would like to get it a few inches from the ground. I am planning on some day putting in the engine crossmember I think you guys sell but not right away and I think laying frame will look goofy without getting the front low.. I want a bit of a rake with the front lower than the rear but I also want the rear 22's to tuck.. I am going t o run 20's in the front. i actually plan to do the engine crossmember and rack and pinion after I rag out the current 350 that is in it now. I then plan to put in a ls1 when so i can do it all at once.. I just want to figure out the best way to do the driveshaft. Thanks for any help.
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 07-08-2008, 03:55 PM   #5
bguild
bguild's Avatar
I was hoping to mimic someone elses set up on the board here.. I know someone else has done what I am trying to do.. Anyway other help out here on this? What are you guys running that have air ride.. are you using the stock crossmember just modified or a 2 piece driveshaft?
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 07-08-2008, 05:03 PM   #6
Slammed67
Progress = 0%
Slammed67's Avatar
I'm running the stock driveshaft but only have the bolt-in c-notch. Any lower than that, and I think you'd need to modify the "driveshaft loop" portion of the center cross member. Or go with one of these http://www.earlyclassic.com/ProductI...02-6372TAX.jpg
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 07-09-2008, 04:43 AM   #7
Frizzle Fry
Frizzle Fry's Avatar
Cut the top out, set the truck where it'll be aired out, build a new hoop to clear the DS. I have better pics than this somewhere in my build thread:
Frizzle Fry is offline   Reply With Quote
Old 07-09-2008, 08:30 AM   #8
bguild
bguild's Avatar
That pic is exactly what i was looking for.. is there anyway you would know the distance from or heigth of the loop.. I am having a friend come weld some stuff on the truck and when he comes I wont have my airbags yet.. I would like to get this built so I can get my cab back on so then I can mock it up with the cab on. Anyway I will look at your build thread and thanks for the help.
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 07-09-2008, 11:31 AM   #9
VA72C10
VA72C10
VA72C10's Avatar
Since from what i've read, every truck sits slightly differently when aired out, you would really need to try to have the bags in before attempting that. I'd hate to see you do it only to have it be off by 1/2" or something and have to be redone.
VA72C10 is offline   Reply With Quote
