Old 07-02-2008, 09:35 AM   #1
acl
acl's Avatar
Temp Gauge Fix Finally (i Think)
O.K. The easist way to find a problem with a gauge or electrical problem is to have your favorite tool distributor truck come by and attempt to sell you a tools. tell him your issues and let him show you how to use the tool(in this case it is called a POWER PROBE) to find the problem. This is a tool that can add 12v power or ground to the part in question to test. I have a intermittent power supply to the gauge. The circuit board is the problem. I did install a aftermarket gauge to the orig sender and it works fine. I can't thank everybody enough for all the imput and p.m.'s . I need to come up with a circuit board and swap it out. Oh hell i've not done that before, any suggestions. Here we go again. Might trade it for a bicycle. Thanks
Gary
Is this a common prob with circuit boards and should i go new or ok finding a used one?
acl is offline   Reply With Quote
Old 07-02-2008, 10:30 AM   #2
fastazhell
fastazhell's Avatar
Re: Temp Gauge Fix Finally (i Think)
the power probe is my bestest best friend at work. as an electrical and a/c specialist with a huge ford dealership it quickly helps diag lots of electrical concerns. I'd be lost with out mine. way to abuse the tool guy!!!
71 LWB c10- needs more work than I have money!
ASE certified Ford Master Tech
fastazhell is offline   Reply With Quote
