Old 07-02-2008, 10:43 AM   #1
Mark B
Mark B's Avatar
need help with 3 speed transmission mount and driveshaft
I have a 3 on the tree and 250 six in a SWB leaf spring truck.
Does anyone know how or if the tranny is supposed to be mounted to the frame? Right now it is unsupported.
This is a shortened LWB truck. The orginal truck had a 2 piece driveshaft with a crossmember that supported the end of the first shaft back from the tranny. It has a single shaft now, and that crossmember has been partially cut away to make clearance for the driveshaft. The crossmember doesn't support anything at all now. The only drivetrain support are the engine mounts, and I think that is causing some drivability problems.
Any pictures of how this should look would be great.
thanks
Mark
Mark B is offline   Reply With Quote
Old 07-02-2008, 11:18 AM   #2
my70chevyc10
my70chevyc10's Avatar
Re: need help with 3 speed transmission mount and driveshaft
On the three speed the trans mount is mounted to the frame near the bellhousing unlike automatics they have the mount at the tail of the trans. The three speed has 2 big mounts 1 on eatherside of the bellhousing that takes a special frame mounts to atatch it to the frame i have pics of the mounts and bellhousing if you want them.
"Your trucks fast! You must have been going 120 when I passed you."
"Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties...
my70chevyc10 is offline   Reply With Quote
Old 07-02-2008, 11:25 AM   #3
samwise68
FarmBoy.
samwise68's Avatar
Yup.
Three speeds only have the bellhousing mounts - no tailshaft crosmember. they're light enough that they don't really need it - or atleast thats the thinking from the factory, i guess?
It hasn't been an issue in my truck, at least.
-Sam.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
Old 07-02-2008, 11:37 AM   #4
Mt Man Chad
Mt Man Chad's Avatar
Mine trans is unsupported with a 1 pc drive shaft and 3 on the tree.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
