I am starting a new build and it happens to be my first truck. I just bought a 1968 C10 long bed and want to know if the rear end, front spindles, from a 1985 Cherolet Van fit my 1968 c10?
Thanks |
Re: Need Help, interchangable parts 1968 C10
Welcome to the board....first the rear axle issue. You have a coil spring setup now right? The newer axles were mostly leaf sprung so it's not a direct bolt in. You'll be grinding & welding for sure....we've done this on 2bits truck and it was quite the job.
On the spindles I am not sure, but if they are the same as the 73-87 trucks the whole front end will swap in to take the place of yours.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
Measure the width. Usually the van parts are much wider.
Thanks ..looking forward to being a part of this forum. This is my first truck so I'm sure I will end up having alot of questions. Any information is greatly appreciated.
Thanks again Last edited by lunaelement; 07-03-2008 at 04:26 PM. |
