Old 07-03-2008, 01:54 AM   #1
64Magoo
Lets see your hood locks!!!
I am posting this sort of in tandem with my thread about local hoodlums vandalizing and trying to make off with me trucko. How do you all have your hoods locked up? Pictures and or setup instructions would be very very welcome. Thanks!
64Magoo is offline   Reply With Quote
Old 07-03-2008, 03:41 AM   #2
blackedoutharley
Re: Lets see your hood locks!!!
No pics, but I use a Kryptonite motocycle cable lock that has the lock built in and run it through the hood and around the actual hood latch assy... access is between the top of the grill and the grill support panel.
You should be able to pick one up at your local motorcycle shop. This is the one I use.
http://www.kryptonitelock.com/Produc...=1001&pid=1183
blackedoutharley is offline   Reply With Quote
Old 07-03-2008, 09:51 AM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
Look behind your hood latch. You can weld or maybe bolt a bracket behind it and drill a hold through it and use a pad lock on the latch. Someone had a picture of this once but not on this forum.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-05-2008, 03:23 AM   #4
64Magoo
Only 2 people have any interest in locking their hoods in this crowd? Really? Some of your trucks should be sealed in an impermeable bubble so dust can't even get on them and you don't lock your hoods?
Old 07-05-2008, 05:23 AM   #5
blackedoutharley
p.s. I got it at Cyclegear.
There is one on 24th St. in Bakersfield
Old 07-05-2008, 05:35 AM   #6
64Magoo
I actually live about 1 minute from that Cycle Gear haha! I drive by it every morning and afternoon to and from work.
Old 07-05-2008, 10:29 AM   #7
salazar44
65 - Chevy C10
salazar44's Avatar
I also used to use a bike lock. But now that my car nears completion I would like something a little more fancy.
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 07-15-2008, 03:30 AM   #8
64c20crewcab
64c20crewcab's Avatar
I seen a 63 with a pad lock setup. Seems the latch had a hole or a tab&hole in it to accomodate the lock. I should have taken a pic of the set up. Oh well - more research!
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline   Reply With Quote
Old 07-15-2008, 09:38 PM   #9
billydonn
Council of the Elders
billydonn's Avatar
I'm very interested and have thought about locking the hood... but no solution to offer. Just lurking in hopes of seeing a cool idea for now. Sorry for your thefts by the way... I am really glad I have a locked garage. One security idea I have used is pulling the fuel pump fuse when I'm away from my truck to keep someone else from starting it.
66 C-10 Stepside
350 Tuned Port Injection
Tremec TKO-600
Truck Pictures: http://community.webshots.com/user/billydonn
Truck Video: http://good-times.webshots.com/video...ost=good-times
billydonn is offline   Reply With Quote
Old 07-17-2008, 06:49 AM   #10
Fastrucken
Junior Member
Fastrucken's Avatar
I don't have time for the search for ya... But I do remember someone on here converted their hood latch to a cable pull style...
Graham
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome."
Fastrucken is offline   Reply With Quote
Old 07-18-2008, 12:42 AM   #11
wild one
Registered.........
wild one's Avatar
Here's the link to the article mentioned above - Check out Putters "In cab hood release" article - a neat way to secure the hood. http://67-72chevytrucks.com/vboard/s...d.php?t=136797
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 07-18-2008, 01:14 AM   #12
Captainfab
60-66 Nut
The one issue I can see with converting a '60-'66 truch to a inside hood release is that on these trucks the 'latch' is on the hood instead of on the radiator support like on the '67 and newer. Of course a guy could run a release cable on the hood but I'm not sure how well it would work with how the hood opens. It raises up back at the cowl. It might work as long as the necessary slack didn't create a problem.
