Old 05-08-2002, 07:58 PM   #1
RodC
RodC's Avatar
Question Signal Light Cancel
I have my Steering Wheel off to replace the top bearing. Thought I would fix my signal light. It won't cancel when used for a right turn. Both of the springs are there but the cam is cracked.
What catches the canceling springs to cause them to cancel??
Should I replace just the cam or the whole switch?
If you buy a whole switch does it come with the cam?
Rod Childers
'71 C10 Stepside
Rod Childers
'71 C10 Stepside
RodC is offline   Reply With Quote
Old 05-08-2002, 08:01 PM   #2
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Post
Yes the switch should come with the cam and new springs as a unit. confirm with your parts supplier.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 05-08-2002, 08:26 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
dealerships stil have these assemblies new, and arent expensive yet i believe, i got one from there once, came with wiring harness adaptor and all
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
*many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham
current fleet: -71 C-10 350/CH465/3.07- basketcase, #1
-90 Cavalier 2.2L sky blue, a driver
-84 Z28 5.0L/700R4/3.73 daily driver
-84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2
-82 purple Trans Am, project #3
*Paint is overrated*
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 05-08-2002, 08:35 PM   #4
RodC
RodC's Avatar
Post
Thanks guys, I think I'm going to replace the whole thing, However, I still don't see what catches the canceling springs?? Is it the metal cover??
Rod Childers
'71 C10 Stepside
Rod Childers
'71 C10 Stepside
Old 05-08-2002, 09:44 PM   #5
chevy70
Post
I did this to mine last summer But I just replaced the cam and got all new springs from Chevy Duty it fairly simple just take the old cam out transfer the signal lever springs and switch contacts and pop it back in place. the springs cancel by the other plastic cam that rides inside the outer cam and has the horn contact on it
Hope this helps
70 chevy lwb 350 3on the tree
70 chevy c/10 lwb 350 TH350/under construction
91 chevy K1500 350 700r4
chevy70 is offline   Reply With Quote
Old 05-08-2002, 09:52 PM   #6
RodC
RodC's Avatar
Post
Yep I see it now, sorta laid that part aside while I was tryn to figure it out. Funny, the chasis manual even calls it the "canceling cam" shoulda RTFM
Thanks guys.
Rod Childers
'71 C10 Stepside
Rod Childers
'71 C10 Stepside
