Old 11-10-2002, 10:52 PM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
Question 82 350 Hp?
What was the stock horsepower for an 82 gmc 350? I just installed an edelbrock performer plus cam, performer intake, and a 600cfm performer carb. Also, my heads were shot so i had to work with what I have and threw on a set of 305 heads with 1.84 I and 1.5 E valves. I did a compression test and I have between 160 and 175 psi. Is this way too high? What would be my new horsepower approx.?
Thanks for the help!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 11-10-2002, 11:43 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
no thats not too high, the HO305 engines had 9.5 compression ratio, you wont have that much unless you have HO305 pistons, as long as you have regular 58cc 305 heads like the 144014416 ones, 1.84 valves are hurting your airflow, and so are the intake runners volumes of them. stock PSI otherwise is 150
Fast68Chevy is offline   Reply With Quote
Old 11-11-2002, 01:00 PM   #3
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
The 1982 LS9 (Vin A) 350 was rated at 165 Horsepower @ 3800 RPM and 275 ft-lb of torque at 1600 RPM.
Pretty mild by todays standards, but the mods you have made make a really big difference on these early 80's gas guzzling smogged down monsters.
My guess would be that you are around 250 HP now. But that pretty much a SWAG.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 11-11-2002, 01:54 PM   #4
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Hey Fast 68....I thought stock was like 180psi??? or was it just for that motor?? 150?
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 11-11-2002, 02:04 PM   #5
Tom
driving is in my blood
Tom's Avatar
at the crank without water pump or alternoator or any of that crap those 350's were makin 239hp. With your cam+intake you should be up about 40hp. But then you have 305 heads, so Id say your right at about a stock 350, maybe just a tad better.
Old 11-11-2002, 02:51 PM   #6
69GMC910
MOTORHEAD!
69GMC910's Avatar
Just thought I'd add that I removed all of the EGR pollution crap, this probably makes a difference as well.
Thanks for all the help!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
