Old 07-03-2008, 10:36 AM   #1
blazer2007
trouble bending gas line tubing
I,m trying to get some nice bends on a 3/8 steel gas line from fuel pump to carb,I bought a tube bender but all it wants to do is kink the tubing.I,ve tried oil etc. to help it slip,do I just have a crappy bender or what
blazer2007 is offline   Reply With Quote
Old 07-03-2008, 11:36 AM   #2
Pushrod226
Re: trouble bending gas line tubing
I never had any luck with cheap benders. Always do better by hand, thunbs at the center of the bend.
Pushrod226 is offline   Reply With Quote
Old 07-03-2008, 12:35 PM   #3
S10Fan
Old Heap Driver
I use one like this................
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 07-03-2008, 12:36 PM   #4
S10Fan
Old Heap Driver
.....................and paid a massive 6.00 for it.
Bryan
Old 07-03-2008, 01:09 PM   #5
Alex1
Alex1's Avatar
fill the pipe with sand - then bend it. Make sure you clean it out afterwards.
Alex1 is offline   Reply With Quote
Old 07-03-2008, 01:40 PM   #6
87Bob
If you do not have ends crimped on it they make a sleave that looks like a large spring it helps to keep the tube bend uniform through the bend. I have used the bender shown in the photo above and it worked fine.
87Bob is offline   Reply With Quote
Old 07-03-2008, 02:39 PM   #7
BowTieOgre
I have used the bender pictured above with good results with short pieces but got frustrated a few times trying to juggle the tool and piping that was more than a few feet long so what I ended up doing was using several pieces of scrap PVC in different diameters and bending the tubing around them.
Try your local parts store and borrow their kit to see if it works any better.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 07-03-2008, 08:43 PM   #8
impalamark
impalamark's Avatar
I try to bend the pieces first then cut them to length as much as
possible the short lengths will make you mad
Mark
impalamark is offline   Reply With Quote
Old 07-04-2008, 01:56 AM   #9
shadetree
shadetree's Avatar
Like Alex1, I use sand. Cap off one end of the tube & fill with sand. Tamp the sand down & add more sand as needed. Cap off the other end, and now bend with anything, the tubing will not kink.
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 07-04-2008, 09:31 AM   #10
blazer2007
thanks, a tips and tricks thread would be nice to have here with homemade ideas and such
