Old 11-10-2002, 11:02 PM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
170 psi compression!?!
Is this way too high for a pump gas 82 350 with a performer plus cam, performer intake, and 600cfm performer carb. The engine unfortunately has 305 heads. What would my compression ratio be approx.?
Thanx
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 11-10-2002, 11:35 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
150psi is stock, no one can guess what ratio it is, the only real way to know exactly what it is is by measuring cylinder volume- with piston at TDC, and then at BDC, and then by dividing the TCD volume measurement by the BDC volume measurement
Fast68Chevy is offline   Reply With Quote
Old 11-10-2002, 11:41 PM   #3
bigjimzlll
bigjimzlll's Avatar
ok..with a standard bore..with .020 piston down....038 head gasket..12cc piston dish..and 58cc chambers..I come up with 9.62-1 C/R..92 octain area..watch your timing..you should be ok
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 11-10-2002, 11:42 PM   #4
69GMC910
MOTORHEAD!
69GMC910's Avatar
Thanks fast68, I thought i was WAY too high, i thought 130 was stock but i was wrong!
Still looking for horsepower #'s on a stock 82 350, and with my minor modifications an approx. hp.!
Thanks again
And thank you bigjim, 9.62 sounds pretty decent, it's just too bad I'll get very little rev out of those 305 heads.
Thanks for working that out!!!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 11-10-2002, 11:44 PM   #5
cableguy0
i dont mean to sound rude but u most likely killed all hopes of performance with those choked out 305 heads. if i were u i would start lookin for a set of 350 heads to swap in
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-10-2002, 11:48 PM   #6
69GMC910
MOTORHEAD!
69GMC910's Avatar
It's just a winter beater cableguy, so i really don't care at the moment what heads I have as long as it gets me to work and back! I will definitley have to look into some new heads though.
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 11-11-2002, 12:17 AM   #7
67shortie
Green club
67shortie's Avatar
You should be fine, I run 170 cranking psi on my 427 and use 89 octane on the street with no detonation. Give it a try, and see how the engine likes it.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 11-11-2002, 03:53 AM   #8
alta-aj
Pump gas
I have 9.5:1 pistons in my 406 and it runs fine on 87 octane.
alta-aj is offline   Reply With Quote
Old 11-11-2002, 07:10 AM   #9
bigjimzlll
bigjimzlll's Avatar
one thing that really makes a differance is the cam...the more cam you have,the more C/R you can run, without detonation. This is called dynamic compression ratio http://cochise.uia.net/pkelley2/DynamicCR.html
you can go to this link and it will explain it, also you can down load the program and figure out what dcr you have
Anderson,CA
Old 11-11-2002, 02:57 PM   #10
69GMC910
MOTORHEAD!
69GMC910's Avatar
I removed all the pollution crap off the truck as well, so it seems to run alot better now, the 73-87 board says this engine would currently be sitting at anywhere from 230-250 hp, Sound right? I hope so!!, Next step is shorty headers and 3" exhaust!!!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 11-11-2002, 03:09 PM   #11
Fast68Chevy
bigjim knows what he is taking about
i dont even know what dynamic compression is really, heh.
im guilty myself of runnign 305 heads on a 350, ran some 1406 heads on a 72 350 engine, but never drove the vehicle with it liek that, just ran it a couple times and well not long after, the great shape rebuilt .030" over 350 4 bolt spun the rod bearings out of it, suppose bearings didnt like the new high compression.. was a super nice clean strong engine, was not even the tiniest spec of carbon or sludge or metal wear material anywhere in it to be found, not in the lifter gallery or oil pan or anything.. stuck the engine in a high rear ratio th350 83 caprice 4 door with stock converter and .488/.488 cam and stock 80's spreadbore alum intake and stock truck ram horns.. wasnt a good combo, hard to get it to idle in gear like that,, but would burn off right rear tire very, veryyyyyy easily, better intake and bigger valves and lots of converter stall and some headers and 3.73 or 4.11 rear would have helped things.
gonna have to do basically same thing all over again for the most part in this 81 c01 out here, the LG( 305 in it has some kind of top end problem, different timing chain didnt help it any and im tired of messing with it and ive got an 85 truck 4 bolt 350 engine minus the heads here in good shape and it now has 82 305 heads on it and i may just have to install it in the truck cuz i realy have nothing else that will easily go into it with the ESC type exh manifolds it has(7 bolt), the 305 heads on the 350 are ESC heads, and so.....
id have to remove crank from the 350 and have rod bearing journals checked out and or turned for new bearings to feel safe running the 305 heads on it., if a new distributor doesnt fix this LG9, well then.,,,, here goes nothing.... i need a truck and they are very hard to find in complete and running shape- of any year- in the last few years now,
gotta do something..
good luck with your engine.
Old 11-11-2002, 04:26 PM   #12
crazy longhorn
Fabricate till you "puke"
69GMC910, I dont think i would go bigger than 2 1/4" ex haust (duals) on your combo......too big & you loose all the low end tork that you really need on a heavy truck. Im runnin 2 1/2" on my longhorn behind an edelbrock rpm topped 383.......& thats plenty. You dont really need or want 3" pipe till you are in the 450 plus range on hp......
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
