Seņor Member
I'm contemplating transplanting a steel floor into my stepside bed. Has anyone got a tape measure handy to see how wide the main piece of floor is that goes between the wheel wells?
Thanks, Kenneth
Fabricate till you "puke"
Fleetside , tub to tub? I have 39 1 1/2", & the tubs are stretched 5".......so stock should be 49 1/2. Im guessing, you plan to cut down a fleet floor to use on the step?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#3 | |
Seņor Member
Kenneth
I think it might work, & should look good. Your front box panel will be 3/4" too tall, but the mount lip can be cut off & refolded. good luck, & let us know how it goes.....
