Old 07-03-2008, 11:06 PM   #1
bufmatmuslepants
Junior Member
truck wont start, neutral safety switch?
radio comes on, lights go on, wont start, not even try to turn over. if you rock it back and forth it might start. just got back to WV, my roomate is giving me this info, need the truck tomorrow. any ideas?
1979 K10 reg cab short bed 33x12.50s - GONE
1988 4x4 reg cab long bed 337k miles - GONE
1995 Z71 GU6 G80 F44 ext cab short bed 149k 305/70/16s - GONE
1995 NZZ GT4 2dr Tahoe 3" lift 14 bolt sf 155k 305/70/16s - GONE
1994 Z28 M6
1995 Z71 GT4 G80 ext cab short bed 215k GONE
1997 GT4 G80 Yukon 4 door leather, sunroof 168k miles GONE
2003 Avalanche Z71 GT4 G80 165k miles
bufmatmuslepants is offline   Reply With Quote
Old 07-03-2008, 11:16 PM   #2
screwballl
Tonawanda 454
screwballl's Avatar
Re: truck wont start, neutral safety switch?
if the neutral safety switch is loose it can cause that... if you hear it "tick" or click when you turn the key, it may be low battery or frozen starter as well... I would get the battery checked and check the neutral safety switch connection itself.
i have also seen a rash of solenoids going bad here in the south so that may be something else worth looking into.
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 07-03-2008, 11:18 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
does it start in neutral ? also check the fusible links by the battery also beat on the starter a couple of times maybe the starter is going? is the battery too dead to start it? does it click when you try to start it?
if its n ot cranking at all gotta be one of them
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 07-03-2008, 11:21 PM   #4
f.monroe
f.monroe's Avatar
Does it have tilt steering ? If so , try it with the tilt all the way up and all the way down . Seems to pull the rod that activates the actual switch a little farther that way . I have had a truck in the past that did the same thing . It started with the tilt all the way up or all the way down but not in the center . It was just a little out of adjustment .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 07-04-2008, 10:51 AM   #5
bufmatmuslepants
Junior Member
it is not a tilt wheel, and the battery is not dead beause if you rock the truck back and forth sometimes it will just fire up like nothing was wrong. where is the neutral safety switch? and the problem could be it is just loose or broken? thanks for the replys guys keep em coming
1994 Z28 M6
Old 07-04-2008, 10:59 AM   #6
us111
saftey switch is on column almost down to the floorboard.
us111 is offline   Reply With Quote
Old 07-04-2008, 11:09 AM   #7
bufmatmuslepants
Junior Member
ive been searching through the forum and on 67-72s there is a heavy gage purple wire that goes down to the bottom of the steering column to the switch, is it the same iwth 73-87s?
1994 Z28 M6
Old 07-04-2008, 11:25 AM   #8
dammitmitchell
the pollock
dammitmitchell's Avatar
honestly to me it seems like your starter is going, the worm gear on the end of the starter could be still engaged or improperly aligned (from being old or close to dead) and is sticing to your flywheel a bit.... and the rocking can jar it loose..
check the connections on your starter also.. they hve a tendency (on the less expensive starters) to loosen up especially on trucks that re beaten on alot (like me)
but my vote is check starter make sue starter is happy seems like the easiest place to start... then go to the safety switch,
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
