Old 07-04-2008, 12:12 PM   #1
1FAST68
Master cylinder, which lines go where?
My reservoirs are the same size, does the front port go to the front brakes or back. Front are disc with rear drum, master cylinder is for a 71, I am putting a adjustable prop valve for the rear.
1FAST68 is offline   Reply With Quote
Old 07-04-2008, 02:17 PM   #2
Big68
Re: Master cylinder, which lines go where?
I'm pretty sure that the resevoirs are backwards. i.e. back resevoir are front brakes and front resevoir are rear brakes.
1968 GMC, 2wd to 4wd conversion, automatic to manual, 4 in custom lift, 36'' military tires, recent 454 upgrade
1979 Pontiac Firebird, mildly built sb 350, t56 trans
Big68 is offline   Reply With Quote
Old 07-04-2008, 02:40 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
need to know if it is a 1/2 ton or a 3/4 ton
Old 07-04-2008, 02:44 PM   #4
LONGHAIR
You need a disc/drum master cylinder. There is a difference in the volume of fluid moved. The drum style master has a residual vavle that will hold too much pressure on the discs.
Power?
LONGHAIR is offline   Reply With Quote
Old 07-04-2008, 03:09 PM   #5
1FAST68
It is a disc drum master, it is also a 1/2 ton.
Old 07-04-2008, 05:13 PM   #6
LONGHAIR
On a 1/2 ton truck the front of the master is the front brakes.
FWIW, 3/4 ton is the opposite.
Old 07-05-2008, 09:01 AM   #7
1FAST68
thanks
