07-04-2008, 02:01 PM | #1 |
Electrical Starting Problem
I'm sure this is really basic stuff but I need some help. Today, I was changing out the cig lighter and had not unhooked the battery (first mistake). The wire must have touch a ground somewhere and it sparked. I figured I had probably blown a fuse....no big deal. Went to look for the bad fuse, replaced several fuses while there and none of them looked bad. Replaced them anyway. I then went to start the truck and nothing. Not any electrical anywhere....with or without the key on. Since I had been working on the gauge cluster also, I thought maybe I had run the battery down. Stuck the charger on for several hours and nothing. I am lost on where to go from here.....can anyone help? Thanks. Joel
07-04-2008, 03:52 PM | #2 |
sharp as a marble
Re: Electrical Starting Problem
BLOWN FUSEABLE LINK!! On the large post on the starter there will be a burned wire. You may have to look carefully, as sometime the wire will be burned inside the conduit. DISCONNECT THE BATTERY, and remove the 9/16or5/8 nut on the post that attaches the positive battery cable to the starter. There will be a couple of small wires attached to the same post. tug on the small wires and you will find one broken. NAPA will sell replacement FUSEABLE LINKS. Some will have the eye attaches, and you will have to crimp the other end to the wiring harness.
07-06-2008, 12:55 PM | #4 |
Active Member
Also, if you have trouble locating the problem, start trouble shooting (with a meter) at the battery. Follow the positive cable to the starter, etc. Check the voltage at each connection..
07-06-2008, 01:04 PM | #5 |
Long Fleet Club
Mine was doing the same thing but my wire going from the ignition switch to the alt was broke at the fuse panel and grounding out. after I repaired the bulkhead connection it worked fine.
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
07-06-2008, 04:29 PM | #6 | |
its all about the +6 inches
Troubleshoot the SMALL wire from the positive to the fire wall... it should actually be between the battery and the small positive post on the fenderwell. |
07-06-2008, 07:35 PM | #7 | |
Active Member
True, true. However, the reason I mentioned pos lead as a starting point is because he has no voltage anywhere??? By checking the pos lead it will tell him if he has voltage from the battery, and also if the terminal is not internally defective (had that problem myself). That small wire Longhorn Man is talking about should either have a fuse or be a fusible link-if I remember correctly. |
07-06-2008, 08:12 PM | #8 |
take both battery cables off clean both ends(thats a total of4) and hook them backup
07-06-2008, 09:49 PM | #9 | |
Long Fleet Club
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules Last edited by cameeks; 07-06-2008 at 09:50 PM. |
07-06-2008, 10:23 PM | #10 | |
While all that is true, and valad points, since he started with a running truck, sparked an unfused wire, and then had no power, then the normal troubleshooting would follow that small wire to the fuseable link, or if it is missing, then across the core support to the firewall. The reason he gets no crank when he turns the key.
07-09-2008, 04:08 PM | #11 |
I just wanted to give everyone an update to what I found on my electrical problems (that I created). First, the black and red wire running into the plug at the ignition switch were fried as well as the plastic plug that goes into the ignition switch....it was melted and severely damaged. I replaced both the plug and spliced in new wires to the harness. Secondly, the wire that runs through the firewall to the starter was also fried. Needless to say, I will never work on the electrical again without disconnecting the battery! Thanks to all that contributed to this problem...I greatly appreciate your input! Joel
07-09-2008, 09:09 PM | #12 |
Sounds like someone has redone some of the wiring. That wire from the starter to the firewall is probably the one I was talking about that originally ran from the battery to the firewall.
