07-05-2008, 03:21 AM | #1 |
PIMPING RIDES
65 Body To 81 Frame
guys has anyone ever put a 65 c/10 body on an 81 c/10 frame if so what is the pros and cons?
1964 CHEVY 1/2 C/10 FLEET 1981 CHEVY 1/2 C/10 FLEET 1995 DODGE 1500 V6 FLEET EAST http://www.flickr.com/photos/bigasspimp/?saved=1 |
07-05-2008, 03:26 AM | #2 |
Re: 65 Body To 81 Frame
why would you want to whats the point????
07-05-2008, 04:01 AM | #3 |
PIMPING RIDES
will it fit ? i'm having problem with the 65 frame ,got an 81 donor that i was using parts to fit my daily driver .i thought maybe i could throw the cab and bed from my 65 onto the 81 frame .
07-05-2008, 04:56 AM | #4 |
1961 crewcab
how bad off is your 65 frame?
I would switch all the 81 frontend components to the 65, since they are a near bolton, and keep the stock car style rear set up from the 65, since it is a better suspension setup for a streetrod/custom ( if you are not going to use it as a work truck). I did a post similar to this awhile back , and that is what everybody told me as well. |
07-05-2008, 07:31 AM | #5 |
PIMPING RIDES
guys i'm trying to find out if it can be done ,does anybody know ?
07-05-2008, 07:51 AM | #6 |
IN 1992 i put a 1965 GMC truck cab and bed on a 1977 chevy 4x4 truck frame.I use the 65 GMC cab mount brackets.Then i added 3-inches on the front cab brackets to level the cab.
07-05-2008, 09:00 PM | #7 | |
Rust Buster
Yes it can. I would suggest centering your front fenders with radiator support attached over the center of the newer axle, mark and mount your radiator support. Then work your way toward the back of the truck adjusting the cab mounts as needed. |
07-06-2008, 06:41 AM | #8 |
I Still Dont Understand Why You Would Want To, Just Take The Whole Damn Front Crossmember Put It On The Other Truck, Otherwise Your Going To Be Cutting And Rewelding Body Mounts Trying To Get It To Sit Right, If Its A Daily Get Some Power Discs On It And Maybe Some Cushy Seats And It Will Be The Same Damn Thing As The 81! Your Doing Way To Much Work If You Try To Swap Boddies......completely Uneeded....................by The Way Anything Is Possible Of Coarse It Could Be Done, Is It Worth The Time And Money......hell No, Take A Look At Frizzle Fry's Build Threds Then You Will Know What Im Talking About When I Say Anything Is Possible If You Have The Right Tools, Money And Know How!
07-06-2008, 09:09 AM | #9 | |
Rust Buster
Maybe he's having the same problem as me....a frame beyond saving. Maybe he has more time than monetary resources. Or may be he just wants a challenge to test his fabricating skills. It is his vehicle, we should make suggestions but never TELL a person what to do. OPINIONS VARY! |
07-06-2008, 02:24 PM | #10 | |
PIMPING RIDES
07-06-2008, 11:11 PM | #11 | ||
CHEVY ONLY |
07-06-2008, 11:58 PM | #12 | |
60-66 Nut
Several years ago I mounted a '62 C10 body on a '75 C10 frame. When it was all done it sat about as high as a stock K10 due to basically having a body lift.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 07-06-2008 at 11:58 PM. |
