Old 07-05-2008, 04:42 PM   #1
Ford Assassin
Ford Assassin's Avatar
Question Popping & Banging Under Heavier Throttle...
Hey guys I recently picked up a '69 C10 SWB for a little truck project that me and the better half can do together.
Anyway, it has a late '70's 350 engine in it (junkyard special I am sure) and it idles and drives normal very smooth. However, anytime I get into the throttle past half way and the engine speed goes up it starts missing and popping/banging through the exhaust. I can feel the loss of power as well.
Its got a HEI distributor already, but I went ahead and changed the cap, coil, rotor, plugs, wires, etc. and I played with the timing (10* initial). I also swapped the carb out for another one and still nothing has improved. I haven't pulled any valve covers yet, but I don't hear any unusual valvetrain noise.
Ideas?
Thanks guys!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 07-05-2008, 05:29 PM   #2
caminokid
Chevy nut
caminokid's Avatar
Re: Popping & Banging Under Heavier Throttle...
Cam. Thats what's wrong with the 350 I took out of my 69 fleet.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 07-05-2008, 05:38 PM   #3
68gmsee
Active Member
68gmsee's Avatar
I agree... It was a common problem with early 350's. The symptoms you give is what happens when the lobes are worn.
Be sure and check for any vacuum leaks also.
68gmsee is offline   Reply With Quote
Old 07-05-2008, 05:39 PM   #4
Wrenchbender Ret
Yes. Pull the valve covers & turn the engine. Watch for valve/s that don,t open very far. You probably have lobe/s worn down on the cam.
Wrenchbender Ret is offline   Reply With Quote
Old 07-05-2008, 06:09 PM   #5
67shortie
Green club
67shortie's Avatar
that's the first thing that 'popped' into my mind when I read this too, bad cam.
I know, bad joke
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 07-05-2008, 06:32 PM   #6
Ford Assassin
Pulled the driver's side valve cover, its a flat lobe on the exhaust side on #5. Maybe more I haven't pulled the passenger side valve cover yet.
Cable
