Old 07-05-2008, 05:24 PM   #1
fastazhell
fastazhell's Avatar
working on truck today, found nasty stuff... :whine:
well i got off work early today and tried to get a few things done on the truck and found some crappy stuff. I was taking out the stock trailing arms and springs to do my C-notch and install the CPP arms and slam bags when noticed that the upper spring perch is rusted pretty much through and is falling to pieces. being bummed about that, i moved onto another area since I had a helper show up. Decided to start removing the old busted windshield and some of the interior stuff in anticipation of pulling the cab here in a few weeks. well once the glass was out, I noticed that the whole top side of the flange is rusted and is gone by the passenger side corner. I'll post pics in a few minutes, but what are your thoughts on this? new cabs are not easy to find here in florida, heck parts in general are not easy to find and if you do, they are a fortune...
71 LWB c10- needs more work than I have money!
ASE certified Ford Master Tech
fastazhell is offline   Reply With Quote
Old 07-05-2008, 05:41 PM   #2
fastazhell
fastazhell's Avatar
Re: working on truck today, found nasty stuff... :whine:
driver side:
passenger side top:
passenger side bottom:
top center:
Spring perch:
Old 07-05-2008, 06:45 PM   #3
Gray Ghost
Gray Ghost's Avatar
Fiberglass is the answer to the windsheild area fubar...I helped fix one on my 67 before it was mine. There's a new one most paint shops have that has the netting in it already...very cool.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 07-06-2008, 12:00 AM   #4
jorgensensc
jorgensensc's Avatar
DO you want my honest opinion? I hope so. I would say ditch the cab and start fresh. You are going to have a ton of rust issues in that window frame forever, unless you cut it all out and replace it. I bet in between the roof panels is severely rusted. You can try fiberglass, but I don't think in the long (or short) run it will last very well. You will have rust bubbles popping up again. I know that they are hard to find in your area. If you really want one of these trucks, I say make a trip out this way and towards az, nv, california and pick up something a little less damaged. It can be fixed, but you will probably spend a lot of money and time and may have problems anyway. JMHO.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 07-06-2008, 12:56 AM   #5
chevychase
chevychase's Avatar
Shawn
I'm going to have to agree. I had a busted up cab myself, I'm sure I saved money and tons of headaches by buying a decent cab.
Joe
chevychase is offline   Reply With Quote
Old 07-06-2008, 01:12 AM   #6
Pont406
Here in California they do come up for sale sometimes. I am also looking for a cab..This is not mine. http://losangeles.craigslist.org/lac/pts/738204557.html
Pont406 is offline   Reply With Quote
Old 07-06-2008, 02:05 AM   #7
HoupPhotography
Shawn
I would also agree!
If your interested in coming out this way, I can help you find one and maybe even give you a little food and a pillow...
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 07-06-2008, 02:27 AM   #8
bowtieboy93
bowtieboy93's Avatar
i have to agree with above
theres gonna be more head ache and pain in fixing that rather than just buying a new cab
Travis
travis_moffatt@hotmail.com
1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces.
1991 GMC Sonoma, IROCS s10 grill
1963 Ford Galaxie 351/C4
bowtieboy93 is offline   Reply With Quote
Old 07-06-2008, 09:10 AM   #9
fastazhell
fastazhell's Avatar
i thought about it last night and I also agree. with the amount of money and sweat equity that will be involved to fix it, I don't think it will be worth it. plus thats obviously not the only problems with the cab either. needs rockers and corners and doors. The frame should be a rather easy fix. I am prob going to do something along the lines of the ART rear shock mount in their strong arm kit. Unfortunately you guys are right, too much will be involved in getting that cab right. thanks for the honest input!!
Old 07-06-2008, 04:13 PM   #10
longhorn70gmc
longhorn70gmc's Avatar
There are allot of healthy Cabs out here in Cali in the yards. Good Luck on the truck.
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 07-06-2008, 04:24 PM   #11
HoupPhotography
Hey man, Look what I found for YOU!!!
Click HERE
Old 07-06-2008, 04:37 PM   #12
Kurt L
Kurt L's Avatar
check with mother truckers in bradenton.
mothertruckers.com
Kurt L is offline   Reply With Quote
Old 07-06-2008, 04:52 PM   #13
Psycho71
Psycho71's Avatar
We see a lot of decent cabs pop up around here now and again. And Tx is only about halfway to Cali and Az. You might get some peeps in the San Antonio and west areas to start looking for ya.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 07-06-2008, 05:00 PM   #14
Critter
Future TOTM Winner
Critter's Avatar
ROAD TRIP! There are a lot out in Cali like others have mentioned, but I really don't think you have to go that far. There are plenty of good ones in Texas (the farther west the better), New Mexico, Arizona, Western Oklahoma...etc. The internet is definitely your friend in this case.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 07-06-2008, 05:02 PM   #15
Critter
Future TOTM Winner
Critter's Avatar
Jay
Ha! We were thinking the same thing at the same time I guess...
