Old 07-05-2008, 11:50 PM   #1
harbourmicah
harbourmicah's Avatar
serpentine setup question
i was wondering from what late model motors i could pull a serpentine setup to put on an older small block in my truck. will any small block setup work except for the LS blocks? not real sure about what will fit. what have yall put on your trucks if you have serpentine. i cant afford any aftermarket setups so im just looking at factory stuff.
1966 chevy short step- under construction
http://www.fquick.com/harbourmicah
harbourmicah is offline   Reply With Quote
Old 07-06-2008, 12:09 AM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: serpentine setup question
I think on sb you can use years 88-95. I got one from a 90 chevy truck but never used it. Also.. You have to have the assesory holes in your heads to use the serpentine system..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-06-2008, 01:01 PM   #3
Chevysdominate
Chevysdominate's Avatar
I grabbed a serpentine system out of a 1993 chevy full size truck and it fit like a glove. You need to make sure you get all the accessories with it though (alt, powersteering pump,etc). It really tucks all the accessories up tight to the engine and makes it a lot easier to intall headers. Good luck.
Chevysdominate is offline   Reply With Quote
Old 07-06-2008, 01:41 PM   #4
62 short step
62 short step's Avatar
How about the water pump? Do you get one from the same year truck? Its a reverse rotation pump right?
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 07-06-2008, 01:44 PM   #5
Chevy Fleetside
yes sir.....
Old 07-06-2008, 02:24 PM   #6
scotts62
One day...
scotts62's Avatar
Yep, mine is off of a 4.3 chevy, all the same just 2 cylinders cut off
I just need to figure out how to mount the york compressor where the power steering pump was..
Scott
93 crew cab build
Project 62
Old 07-06-2008, 09:28 PM   #7
TR65
TR65's Avatar
I know you don't want aftermarket but you can get a simple billet system on evil bay for about $85. I used one and it works good. But if you have more accessories I guess the stock system would be better.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
