Old 07-06-2008, 01:04 AM   #1
Pont406
gas gauge reading
Is it just me or did anyone else notice that when a gas gauge reads between full and half a tank, gas seems to last longer? After half a tank and it goes to empty faster. Maybe my gauge is bad.
Pont406 is offline   Reply With Quote
Old 07-06-2008, 06:47 AM   #2
caminokid
Chevy nut
caminokid's Avatar
Re: gas gauge reading
No mine is the same way. Just about every vehicle I have owned is like that.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 07-06-2008, 08:50 AM   #3
LONGHAIR
Yeah, the top "half" is usually bigger than the bottom "half".
It can be "adjusted" to some degree by swapping to a "universal" type sender. These will allow you to move the pivot point up a little bit, making the top, in effect, smaller.
So if it is really that important to you, it can be done.
LONGHAIR is offline   Reply With Quote
Old 07-06-2008, 12:50 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Aside from float and guage adjustments:
On most gas tanks, the gas tank float guage only goes up to a certain level. But, there's still extra space above the tank including the filler neck.
When you fill the truck up past the last "full" mark and you start driving it, you're using that extra gas. So you have to burn all the gas on the space above full mark and filler neck before the float starts to move.
Once it starts to move (as in my truck) it seems to go pretty fast.
68gmsee is offline   Reply With Quote
Old 07-06-2008, 01:02 PM   #5
70LonghornCST
Moderator
70LonghornCST's Avatar
Originally Posted by 68gmsee View Post
...So you have to burn all the gas on the space above full mark and filler neck before the float starts to move.
Especially at today's prices
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 07-06-2008, 01:15 PM   #6
cameeks
Long Fleet Club
cameeks's Avatar
I guess mine is broke (the gauge). Mine used to show way past full when I topped it off. When I drive it around and get the tank down it seams to show right even goes down to Empty. I thought when I got my new tank w/ sending unit that it would work but it is the same.
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 07-06-2008, 02:43 PM   #7
68gmsee
Active Member
68gmsee's Avatar
There's no problem with the gauge if it reads above the last full mark. Most of the gauges will do that. What I meant on my post is that after the tank float reaches it's maximum upward travel, there's still space left in the tank.
This extra space, inluding the filler neck area is what you use before the float will start to move down again.
On mine, I usually drive it for about 20 miles or more before the gauge will start to move...
