Old 07-06-2008, 03:49 AM   #1
68c10guy
68c10guy's Avatar
Door sill plate. And new tranny
What are the screws going into? i have two or three that are loose. How do i fix them? And as soon as i finish my vacation in Hawaii im going to pick up my new trans. Its a 700r4 out of a 92 astro van. Lockup converter pretty much base model. What seals should i get just to freshen it up? tia
68c10guy is offline   Reply With Quote
Old 07-06-2008, 06:47 AM   #2
JimKshortstep4x4
Re: Door sill plate. And new tranny
The retaining screws screw into the edge of the floor and can be seen sticking through underneath. If the floor is solid, the next larger screw diameter will work, usually. If the floor is not solid then a sheet metal repair can be made to fix the problem.
JIm
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-06-2008, 11:07 PM   #3
68c10guy
68c10guy's Avatar
ok thanks i wasnt sure if it was some type of j-nut or what. how bout the tranny seals though?
Old 07-07-2008, 10:50 AM   #4
raggedjim
raggedjim's Avatar
I've also replaced the sheet metal screws with machine screws and nuts. That works well if the metal has streched too much to get a larger sheetmetal screw to grip.
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
