1961 crewcab
converting to dual headlights?
I have a 63 wiring harness, is it as easy as just plugging a 60-61 grille and harness in?
Or will I have to change a bunch of stuff? |
Re: converting to dual headlights?
Having not done it, you can take this as you'd like but the only difference in the front harnesses should be the two connectors (each side) for dual headlights as opposed to one.
If you can make the grill work, the electric should be easy. (BTW, I wouldn't bother with a harness, I'd just fab up my own) |
1961 crewcab
that is what I was hoping, that the connector where they go through the rad support was the same....
The connector is the same at the rad support.
Seriously consider upgrading to headlight relays. The factory harness feeds power to the headlights thru the headlight switch without using a relay. This is a hefty (read as ridiculous) load to be switching that way. It leads to headlight switch and dimmer switch failure. By using relays, your headlights will be noticeably brighter and safer, plus your switches will last forever.
------------------------------- '66 GMC Custom Fenderside LWB '90 IROC - L98 '97 1200C Sportster |
KOFFIN DRAGGER
I agree with anthony, and the 6066gmcguy site has a whole how to on it. I will find the linky for you.
http://www.6066gmcguy.org/HeadLights.htm Last edited by kdrodworks316; 07-06-2008 at 01:43 PM. Reason: add link |
1961 crewcab
funny I just read that relay article the other night. those will probably be done in the future.
+1 on the relays, I didn't suggest it 'cause I figured everyone else had already done it.
#9 | |
1962 C-10
It will plug right in...
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
