Old 07-06-2008, 10:21 AM   #1
fatboys69
fatboys69's Avatar
Aftermarket parts BLOW !!
Have been trying to get some work done to my 69 ( posted in another thread added new doors and internals and am now adding 1 piece windows ). Went ahead and put the windows in ( while I was waiting on my new window setup ) for a local cars show this weekend. Got them all together and after rolloing the passenger window up and down about 5 times the NEW window regulator BROKE and will not roll up or down !!! Fortunatly I kept the old one so I can get it back to working. Got the parts from LMC ( TIAWAN MADE CRAP !!!). Also bought new door latches that will not work for crap either !! So I ended up using my old ones there also !!! Does ANYONE make repop parts that are worth a CRAP !?!?!?! Has anyone else had probems with LMC parts ?? This is a royal PAIN in the A$$ NEW PARTS AND THE BREAK !! My problem is the parts were bought 5 years ago so i can't return them. So after the "NEW" aftermarket doors not fitting the best and now this, it is OEM or NOS ONLY for all my projects from now on !!!!
fatboys69 is offline   Reply With Quote
Old 07-06-2008, 10:44 AM   #2
Big Block
Big Block
Big Block's Avatar
Re: Aftermarket parts BLOW !!
Most repo crap is nowhere near the quality of NOS. Sorry your having problems. Depending on what part you need sometimes it better to find NOS. I used repo fenders and they were not a good fit at all. Good luck with your projects.
Big Block is offline   Reply With Quote
Old 07-06-2008, 10:47 AM   #3
67_C-30
I have a radical idea!
67_C-30's Avatar
Unfortunately, that seems to be the way it is on most things. The only decent aftermarket parts that I've never heard muchg bad about is the bedsides, which shocking considering the size of them. Most of the doors, fenders, hoods, and tailgates I've seen suck. I have 9 parts trucks, and I have had people get mad at me because I won't sell any rust-free panels (unless I have several). The only thing I plan on using aftermarket for my '69 C-10 build is interior stuff, grill, bumpers and trim - mainly because of the lack of good used stuff and the cost of NOS.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 07-06-2008, 02:56 PM   #4
Ford Assassin
Ford Assassin's Avatar
Even Goodmark for bad panels? I am surprised because of good things I normally hear.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 07-06-2008, 04:05 PM   #5
longhorn70gmc
longhorn70gmc's Avatar
It seems these days a good donor truck is the answer, but everyone does not have the room for them. I just put a new door hinge on and it is tight as ever. The door is adjusted but it is not the same. Everyone here on the board recommends board vendors for the most part. LMC has always had a Bad rap as far back as I remember. There magazines make great how to fix it books. Good Luck and never give up on our fine passion for trucks.
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 07-06-2008, 06:54 PM   #6
fatboys69
fatboys69's Avatar
I don't think I will ever loose the passion for these trucks, I'll just stop, step back, and re-group ( and learn from the experience LOL ). All will work out, now I am struggling with the 1 piece window set-up to get it to function properly. Oh Well !!! If it was easy Monkeys would be doing it !!!
Old 07-06-2008, 08:44 PM   #7
67_C-30
67_C-30's Avatar
Every one piece window conversion I have seen (cars and trucks) gets real ragged after just a little while. They seem to rattle, wobble, and don't go up and down smoothly. I like the vent windows, and use them frequently in all my trucks, so I think I'll stick with them.
My trucks
Old 07-06-2008, 09:03 PM   #8
70' GMC
HERE.......Somewhere
70' GMC's Avatar
What about tri pro???
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 07-06-2008, 09:23 PM   #9
**grumpy**
**grumpy**'s Avatar
I have, what I believe to be, a goodmark 2" steel cowl hood on my 69 suburban. I cannot get it to fit right.
We've done everything from hogging out all adjustment holes, pulling, etc. and it still fits like crap.
I'm about to yank it for a stock hood.
I'm not picky about fit and finish, for the most part, but it just doesn't sit well.
Anyone else have trouble with these hoods? or are they other company's repop'n these? Maybe I have a reject built on a friday at 3pm before a big holiday weekend!!??!
Road Hounds
**grumpy** is offline   Reply With Quote
Old 07-06-2008, 10:20 PM   #10
jkaylor68gmc
jkaylor68gmc's Avatar
I have a mustang II under my truck that was bolt-in. It is awesome but it takes 1-inch of shims to get it to -1 degrees of camber. You would think it would be easy to design a kit that is square, apparently not.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
