Old 07-07-2008, 07:44 AM   #1
davio
repo doors
After setting the doors and painting the cab and doors I put the door seals in and now the doors wont even close. I have ground the slot in the hinges and can't get them to work. Anyone have this problem and a cure?
davio is offline   Reply With Quote
Old 07-07-2008, 08:33 AM   #2
Re: repo doors
You'll need to tweak the door & latch adjustments a bit again. Adding new rubber always changes the alignment a bit. Unfortunately it is mostly trial and error. Once you get the seals broke in, you may need to tweak things again.
Good luck.
Old 07-07-2008, 09:06 AM   #3
jkaylor68gmc
jkaylor68gmc's Avatar
Re: repo doors
new doors? Does not surprise me. FatBoys 69 and I did a set on his truck and they were HARD, It still needs a bit of alignment. Quality in this area really needs to step up.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 07-07-2008, 09:28 AM   #4
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: repo doors
Even on original doors when new seals are added you need to readjust. I could barely shut mine once I installed new seals. They are still going to be quite tight and you will have to close them with authority!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
