06-10-2008, 10:07 PM | #1 |
350 vortec motor/complete/roller cam/4 carb
(been awhile since i've been on here)
i'm selling a 350 complete engine, it was originally out of a 96 truck, i had my engine builder (very well known around here) completely rebuilt it, it only had 33k miles on it-thus why i originally bought it.... ..standard bore, (had "0" wear in the cylinders),.has new rods, pistons (stock-something like 9:5:1) new GM performance roller cam (same as ram jet 350) , new timing chain/gears, new cam bearings, main bearings, new oil pump, new GM oil pan, roller lifters, new GM harmonic balancer completely re-done vortec heads, new springs (good for 500 lift), new retainers, locks, etc...ALL parts bought from pace performance parts dot com block came drilled for mechanical fuel pump, and the cam has the lobe for a mechanical pump as well, and has older style timing cover comes with the hardened distributor gear for the roller cam, and new GM performance parts chrome valve covers needs only an intake, and distributor i have quite abit of $ in this, but i'll sell it for $1k firm i'll try and post up some pics in the next day or so if there's any interest, i'd rather not ship, i'm in elkins west virginia, my zip is 26241 thanks klambert@cebridge.net
1987 350 TBI lowered 5/7 |
07-07-2008, 11:05 AM | #2 |
Re: 350 vortec motor/complete/roller cam/4 carb
bumpin this one up
new price, complete roller motor, $900
1987 350 TBI lowered 5/7 Last edited by bigarmzz; 07-07-2008 at 11:06 AM. |
07-07-2008, 02:11 PM | #3 |
350 roller motor, vortec heads,4 carb set up
..standard bore, (had "0" wear in the cylinders),.has new rods, pistons (stock-something like 9:5:1) new GM performance roller cam (same as ram jet 350) , new timing chain/gears, new cam bearings, main bearings, new oil pump, new GM oil pan, roller lifters, new GM harmonic balancer completely re-done vortec heads, new springs (good for 500 lift), new retainers, locks, etc...ALL parts bought from pace performance parts dot com block came drilled for mechanical fuel pump, and the cam has the lobe for a mechanical pump as well, and has older style timing cover comes with the hardened distributor gear for the roller cam, and new GM performance parts chrome valve covers needs only an intake, and distributor i have quite abit of $ in this, but i'll sell it for $900 i'll try and post up some pics in the next day or so if there's any interest, i'd rather not ship, i'm in elkins west virginia, my zip is 26241 thanks klambert@cebridge.net
1987 350 TBI lowered 5/7 Last edited by bigarmzz; 07-07-2008 at 02:20 PM. |
07-07-2008, 02:34 PM | #4 |
67-72 Addict!
Re: 350 roller motor, vortec heads,4 carb set up
Wow, for $900 you can't go wrong
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
07-07-2008, 03:54 PM | #5 |
thanks, i appreciate that
the person that buys this is going to be very happy
1987 350 TBI lowered 5/7 Last edited by bigarmzz; 07-07-2008 at 03:55 PM. |
07-08-2008, 04:56 PM | #6 |
computer illiterate
how far are you from nashville. are you coming to the board meet?
72 2wd blazer 72 swb 4x4 |
07-08-2008, 07:51 PM | #7 | |
i'd love to come to the board meet...unfortunately, i work a WHOLE lot, so time wont allow it, i wish it did, but it just doesnt
07-08-2008, 10:29 PM | #8 |
Are you going to the Board Meet in Big Sandy, TN this weekend?
George Morgan Hernando, MS '69 C-10 swb fleetside '72 GMC swb Stepside |
07-08-2008, 10:36 PM | #9 |
VA72C10
great deal...makes me reconsider building mine...do you have the specs on the cam and the receipts for the work?
07-09-2008, 08:15 AM | #10 | |
Detailed Description This hydraulic roller design is used on the 383 truck and Ramjet 350. The duration at lash point in degrees (intake/exhaust) is 288/308; duration at .050" tappet lift (intake/exhaust) is 196/206 and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 431/451. Valve lash is zero/zero and lobe centerline is 109 degrees. This camshaft is a great upgrade for 1996-2000 Chevy/GMC trucks equipped with the L31 Vortec 350 Engine. This cam is great for additional bottom end torque. If installed in one of these trucks, a custom computer re-program is needed. i'm sure i probably have the receipts somewhere, just need to find them...i wasnt terrribly worried about keeping records, b/c, my plan wasnt (at the time) to sale the thing...but i'm sure i can find them though
07-09-2008, 03:10 PM | #11 |
can you ship it I live in portland Or 97217 is the zip
07-09-2008, 04:36 PM | #12 |
i "would" be willing to ship it, but you'd need to make the arrangements......if this is something that you'd be interested in, pm me, and i'll give you a number to reach me at
07-09-2008, 06:41 PM | #13 |
Man, if I hadn't just paid to get my 383 done, I'd buy this! on a side note I shipped a motor and trans from AZ to FL for a $300, it only takes a pallet and the truck comes by to pick it up.
07-09-2008, 06:59 PM | #14 | |
i can pallet this up, no problem if someone wants to have it shipped the only reason i'm selling this, is b/c i dont have anything to put it in anymore...i got into choppers and building bikes alittle over a year ago ...just a shame sitting on the stand like this
1987 350 TBI lowered 5/7 Last edited by bigarmzz; 07-09-2008 at 07:03 PM. |
07-09-2008, 07:02 PM | #15 |
VA72C10
I will pass only because i want to do a 383 as well even though this is a KILLER deal!
07-09-2008, 07:13 PM | #16 | |
Merged........please don't double post. You bumped up the old thread, then copy & pasted it into a new post in a different place....
From the rules..... Quote:
07-09-2008, 11:10 PM | #17 |
i would have appreciated it if you would just have pm'd me about this, but you can go ahead and delete the other post, thank you
07-12-2008, 01:04 AM | #18 |
VA72C10
bump for you
07-13-2008, 08:22 PM | #19 |
Im in need of a motor.I dont know much about how this will fit in mine. I have a 72 swb with AC.Can this motor be ran without a computer and will it bolt in my truck without changing a lot. edin355
07-14-2008, 09:56 AM | #20 |
motor is SOLD
thanks to all forum members!
