Old 07-07-2008, 06:53 PM   #1
chaileyk5
How bad is it gonna leak??
Dad bought the 72 new. Its got 95k on it. The top has never been off of it, and I'm itchin to do it
How bad is it going to leak when I put it back on in a couple of months?
chaileyk5 is offline   Reply With Quote
Old 07-07-2008, 08:08 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: How bad is it gonna leak??
How shot are the body mounts? I'd suggest replacing them before you crack the top seal for the first time.Doing it while everything is still aligned and the top keeping it rigid will make putting it back on much easier and less likely to leak. If the body mounts are shot, and most likely they are, when you pull the top, the body will sag in the middle. This can cause the doors to bind and rattle and make putting the top back on difficult. You'll also see your ride quality improve with new body mounts.
If you get a good seal in the corners of the windshield, they really don't leak.
By the way, post some pictures of this 95K classic. We love seeing pictures!!!
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-07-2008, 09:00 PM   #3
Jtrux
I'm a poor spectator
Jtrux's Avatar
I agree with Bouncy, body mounts would be a real good idea. I recommend the polyurethane ones. Without any experience at all it will take the good part of a weekend if everything goes well.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 07-07-2008, 11:13 PM   #4
bouncytruck
SKINNY TIRES RULE!
I'd recommend the rubber repops. I've heard the poly mounts can squeek and are stiffer than the rubber. If he keeps the truck another 36 years, he might need to replace them again.
bouncytruck 1972 K5
Old 07-08-2008, 06:23 AM   #5
vtblazer
vtblazer's Avatar
True on the poly's but they don't 'have' to squeak if a little time is taken to make sure they don't.
I applied a very liberal coating of anti-seize on the poly's I ran, never a sound...ever.
As far as making the ride more firm, of course they do.
It's factory repro rubber mounts for me next time though.
vtblazer is offline   Reply With Quote
Old 07-08-2008, 07:53 AM   #6
Bentblazer
Bentblazer's Avatar
This may be a stupid question but I replaced my body mounts from cab back: how tight do you do the bolts? Are they suppposed to bottom out or do you back off a little?
Bentblazer is offline   Reply With Quote
Old 07-08-2008, 08:06 AM   #7
bigdon-70blazer
There are torque standards for these but I don't have them with me now, maybe someone has....
bigdon-70blazer is offline   Reply With Quote
Old 07-08-2008, 08:42 AM   #8
chaileyk5
What is involved in changing the body mounts? I've never done that before.
Anybody know somewhere online that has a step by step process?
thanks
Old 07-08-2008, 09:13 AM   #9
Jtrux
Jtrux's Avatar
There is sooooo much info on changing these out, just search for it, I would but i'm in a rush right now. I'm not gonna lie, it's not easy.
Old 07-08-2008, 09:26 AM   #10
vtblazer
vtblazer's Avatar
Found these under :blazer body mounts: but there might be more using different search parameters.
5 pages of good reading either-way.
http://67-72chevytrucks.com/vboard/s...earchid=872389
Old 07-08-2008, 11:07 AM   #11
Yukon Jack
Post Whore
Yukon Jack's Avatar
Welcome to the board. All great advice listed above. You must post some pics of this K5 - think of it as your duty!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-08-2008, 12:01 PM   #12
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I agree with bouncytruck on the Body mount material. Urithane does not have any flexability and is almost like welding the tub to the chassis. That is the worce thing that you can do. The chassis in the Blazer, trucks, and suburbans are "C" channel constructed, not boxed tube and are extreemly flexible. The body or tub is spot welded together and is not flexible, so there has to be a material between them to allow one to move and not the other. If you do not allow for the movement the results are welds cracking, and body mounts eventualy pulling through the body. I have seen more than one truck come into my shop with dammage due to urithane bushings. Urithane is good for suspention, but that is it. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 07-08-2008, 05:47 PM   #13
chaileyk5
what are the rubber repops? i've never heard of them
Old 07-21-2008, 08:46 PM   #14
albertarose
albertarose's Avatar
Thanks all this was good info ..my 72 blazer sagged as soon as took the top off ie doors hard to close etc.. then when I put it back on the holes did not line up very well ..under the truck it looks goo though not much rust ..where there is some is inside the cab in front of the doors and the rockers ..other than that the blazer is in very good shape and I really like driving it I bought it as an investment planning to re sell but think I may keep it dont see many of them here in alberta ..any way thanks again for the posts anf info about poly mounts not being a good idea
albertarose is offline   Reply With Quote
