4WD 4 Core rad shroud - Central PA
Good shape but has a crack on the bottom that could be epoxied (outlined in red), the dark black was rain water, not grease!
$50 + shipping
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 07-21-2008 at 07:28 PM. |
Re: 4WD 4 Core rad shroud - Central PA
ttt
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
ttt, i'm gonna patch the crack with epoxy now...
offers?
hey mike has that shroud been cut? dad needs one ill let him see the pic , hes gone for the weekend, whats the measurment from front to rear?like the total width . thanks tony
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 |
i'll get you the measurements. I don't think it's been cut. Appears original to me. I can compare it to another shroud that I have. This one came off my 68 K-10 so I would guess it's all good.
Here's some pics...
28.5" from center hole to center hole on top (overal is a little wider), 9" deep, 18 - 18.5 center hole center hole on bottom width, overall height (top to bottom) is about 21" or so. I zoomed in on the worst area (besides the crack) and it just looks like the factory did a sloppy job building it, hasn't been cut as far as I can see... That area in the last picture could be sanded and smoothed and the crack can be fixed with epoxy, and never noticed. This is what he needs if he has a 67-72 4WD with a 4 core. Might even fit smaller rads too... Let me know... ![]() ![]() ![]() ![]() ![]()
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 07-20-2008 at 02:22 PM. |
ok mike thanks for the pics ill show him as soon as he gets home monday, and will let ya know, but if someone else wants it, let em have it, thanks and what would shipping be to 24477? ups ground perfered
Looks like I might be able to ship it for $16 if I wrap it in plastic (heavy saran wrap stuff), guard the tabs with cardboard and go FEDEX (insured). If I have to box it up then it will be higher.
I'll get it to you for $60 total if that will work for him.
ok mike, not sure what im thinking but dads is 2wd but since you gave the measurements ill check his to see if it will work and let ya know, thanks
only difference would be the thickiness then, the 2WD engines are a few inches forward aren't they?
In that case you could cut a few inches off this one and get rid of that crack at the same time. The stuff isn't that brittle so a jigsaw should breeze right through it.
yep kinda what i was thinking mike, i dont get off work monday till around 3.00pm so ill let ya know, thanks tony
btw do you know the fellow that owns the green 69 shortbed4x4 lifted on i81 right before greencastle exit going north, nice looking truck fom the road, later tony
don't know where greencastle is....
I'll put "deal pending" on this to give you guys a chance. I will be at Carlisle if you are coming up...
#13 |
mike we looked at his and his fan already sits way into the shroud, like way to far,someone has put a diffrent motor in it plus they set the crossmeber foward also, so hes kinda inbetween going with a diffrent radiator, so if someone else wants it let em have it, if you take it to carsile we may see ya there . thanks for taking the time for the measurements, tony
#14 |
no problem... still for sale
