235s on 2in lowered C-10?
I am lowering my 69 step about 2in---anyone have experience with running 235s in front? Will they rub or not?
![]() I should add these will be on a stock ralleye truck rim 8in Last edited by chip46wis; 07-08-2008 at 10:21 AM. |
![]() Join Date: Jun 2002
Re: 235s on 2in lowered C-10?
Probably not, but what is the series? 75's are tall, 35's are short...
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
Sorry---should have mentioned that-----235 75 r 15 thanks
That will put your tire diameter at just under 29" you should be fine, I have a 4" drop in the front with a 28" tire.
Good luck, Rg
Correct me if im wrong, but factory diameter was 27.1" and had lots of roomin the wheels
if you have a 2 in drop your fine it'll take alot more that that for them to rub
Travis
travis_moffatt@hotmail.com ![]() 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
I am a Referee of life.
I'm running235-70-15's with a 2 1/2 spindle drop.I'm not rubbing but I haven't put the inner fenders back in it yet.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Thank you!!!!! I love bigger tires!!
sharp as a marble
![]() Join Date: Jan 2007
I will try and post a pic or two of my 69. I put 2 1/2"
drop spindles on it with a set of 6 lug rallys 15x8. 255/70r15 did not rub. put 225/70r15 on it, but I think I like the other tires on it better. I will go take a oic or two and try and post them in a few I personally think that when I did the disc brakes it has pushed the wheels out from under the fenders. I am planning to send the wheels to TRUE DESIGN WHEEL CO. have them change the offset by an inch. I think I will like that better. Had them do a couple of set of Buick Grand National wheels, and they truned out sweet!! Last edited by cparman; 07-08-2008 at 08:41 PM. |
sharp as a marble
ok here's the pics. I HOPE. I took these in my play room. It was getting dark, and hopefully it will rain tonight.
Thank all of you! Cparman-nice pics of a beautiful truck!!!! thanks
![]() Join Date: May 2008
I run 255R60x17 with 2 1/2" drop spindles with 2" lowering springs and have no problems.
Mine is chopped, has a clutch, and a big block. |
BTW the disc brake swap does move the wheel out about an inch or so. I ran 275/60/15 on all four with a 2-4 drop and had no issues with a 15X8 rim. I was looking for a decent 17" tire size for my 2wd Blazer. I put 3/4 ton suspension under it and bought hummer 2 8-lug 17x8.5" wheels for it and was wondering how much tire I could fit under it. Was looking at a 275/60/17 but it was like 30-31"s tall! How tall are the 255/60/17s??
#13 |
255/60/17 are 29" tall
#14 |
#15 |
72 Chevelle Club
I'm runnin them on the front of mine with lots of drop and I have yet to rub them so you should be fine !!!
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
#16 |
I wish I was a cowboy
![]() Join Date: Apr 2008
Bob 68327, whatcha got in the rear?
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
#17 |
72 Chevelle Club
#18 |
I run 275/60r15s on 15x10 wheels on all 4 corners. This is with a 3" drop spring and disc brake conversion. No rubbing at all ever.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop 70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress |
