07-08-2008, 01:22 PM | #1 |
4x4 front driveshaft ?
Does anyone know if a front driveshaft off a 203 transfer case is interchangeable with a 205 trabsfer case
07-09-2008, 10:11 PM | #2 |
Re: 4x4 front driveshaft ?
I have have or had 3 or 4 205's and 3 203's They were all from years varying from 71-78. They were not interchangeable on any of the ones I have had. I do have both right now and could show you the difference if needed.
The 203 has a flat plate with 4 bolt holes that bolts to the front of the t-case from the drive line side of the plate. The 205 has a yoke on the front of the T-case that accepts the u-joint right from the CV using fine thread bolts from the t-case side of the yoke. Which one are you looking for? I have 2 more 205 front drive lines. Only the 1 203 DL that still needs to go back in the wifes truck.
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
07-10-2008, 01:33 AM | #3 | |
07-10-2008, 01:47 AM | #4 |
I have 3 sizes right now and to tell you the truth I am not sure if any of them are original. One of them most likely is but I am not for certain. but, If you have one wouldn't be easier and cheaper to get a new tube welded in it? They are pretty heavy just to ship it would probably cost as much as lengthening yours.
I would be happy to measure the ones I have for you though. Depending on which one is the correct size I have one thats almost brand new and the other was rebuilt 1 year before I bought my truck (that got torn apart 1 mo. after I bought it) so its got pretty low miles on it too. I'm thinking 100 or 150 depending on which one. Let me know if I need to measure box and weigh one or if you want to just get your re-tubed.
07-10-2008, 07:37 AM | #5 |
Ernesto, I have an original I pulled from a 72 Blazer---can bring it with me but I thought that is was Jamie72 sent you?
07-12-2008, 01:43 PM | #6 |
Here is the difference between the mounting of the 203 & 205 at the transfer case.
07-12-2008, 01:45 PM | #7 |
Sounds like Huck might have one for you. Let me know if you still need one. I'll return your PM with another Idea for you.
