07-08-2008, 01:39 PM | #1 |
67-72 Addicted
Quick Question
Im trying to remove the guage cluster on my 70 longhorn and i cant seem to figure out how to get handle loose on the "lights" switch. the wipper switch ahd a small screw holding it on, but not the one for the lights. Do i jsut keep pulling untill the handle comes off? lol. Thanks
07-08-2008, 01:44 PM | #2 |
Moderator
Re: Quick Question
Actually, there is a certain way to release the nob and shaft as a single unit, but I am at a loss at the moment. I'll get back if someone has not done so by then.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 07-08-2008 at 01:46 PM. |
07-08-2008, 01:51 PM | #3 |
1970 Daily Driver
Re: Quick Question
The set screw is only on the wiper. To get the light switch knob off you will need to reach your hand up under your dash until you can feel the top of you wiper switch that is behind the cluster. You will feel a small metal button. Push the button down and pull the light switch knob out at the same time. The knob and shaft will come out together.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
07-08-2008, 02:05 PM | #4 |
67-72 Addicted
Re: Quick Question
07-08-2008, 02:18 PM | #5 |
Re: Quick Question
2 notes since I just did this 4 times over the weekend between two trucks...remove/install and remove/install on the other one.
1. the button needs to be pressed when the light switch is pulled out (lights on position) - then it pulls right out. 2. be sure to plug the light switch back in when you have removed the dash - or pull the battery/fuse to prevent killing the battery. |
07-08-2008, 02:48 PM | #6 |
Re: Quick Question
Sorry for the hijack, but does anybody know were to get the shaft only?
you never know what you can do until you have to undo something you have done! |
07-08-2008, 02:58 PM | #7 |
Moderator
Re: Quick Question
I may have one. Let me check, I'll send it to you no charge.
70 Longhorn CST Build Adding an AM/FM Decal |
07-08-2008, 04:10 PM | #8 |
Re: Quick Question
I would appreciate that.I have been trying to find triangle rod that small but cant.
07-08-2008, 05:02 PM | #9 |
I am a Referee of life.
Re: Quick Question
Most BB vendors carry a replacement.IIRC they only come in deluxe.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
