![]() Join Date: Jun 2007
81-87 4x4 Center floor section
Looking for a 81-87 4x4 center floor section, preferably out of a 4-speed truck. I recently bought a clean Texas 2wd cab, and am looking for the bolt in section out of a 4x4 to convert this cab to 4wd. If any of you are junking out one of these cabs and have a good center section let me know. Thanks! ...Joe
I'm not speedin'! I'm qualifyin'! |
Re: 81-87 4x4 Center floor section
I will have a center section out of a blazer this by this weekend, just need to pick it up. I bought a couple of parts vehicles. I am only a couple hours away from Springfield.
1976 C-10 shortbed 2wd (work in progress) Mods: Stock 307, 700R4 Transmission, Hurst Pro-Matic shifter, 2100 rpm stall converter, Headman Elite 1 5/8" headers, H-pipe, 2 1/2 exhaust through Magnaflow mufflers, 3.73 Motive gears, superior axels and Eaton Posi carrier http://www.cardomain.com/ride/3136537 |
![]() Join Date: May 2007
You have to pay attention some are glued in. If you are converting a 2wd cab for 4x4 you need to cut the center hump on the 4x4 because under the front of the seat it has hump also for the transfer case. I seen a thread on this a while back. It was easy to do.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Is it a bolt in or glued in, or have you got that far with it yet? ...Joe
I will pick them up on Sunday and will know more. The Blazer is an 83 4X4, I am getting it for the doors and front clip. I'll take some pictures and post them for you on Sunday.
Thanks! Keep me posted. ...Joe
Unfinished Project Club
![]() Join Date: Jul 2005
if you need it i have a 4x4 87 scottsdale cab id be willing to cut the hump out for you.
Thanks for the offer! Is it a bolt in center? If I can't find one locally, I may be getting back to you on it. One of the guys at work that messes with these old trucks said he didn't have one either, but one of the guys he knows may have one, he'd have to ask and get back to me. He commented on how a lot of parts like this aren't reproduced by the aftermarket yet, and since most people don't see any value in the parts, a lot of them are being crushed at a fast rate. Makes them a little bit harder to find, but they are still out there. Anyway, if I end up needing yours I'll definately send you a PM. ...Joe
