07-08-2008, 08:51 PM | #1 |
HERE.......Somewhere
ELECTRICAL Question
This wire keeps coming loose and it just started this today. its attached to the battery post can you buy another wire???
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! Last edited by 70' GMC; 07-08-2008 at 09:12 PM. |
07-08-2008, 09:13 PM | #2 |
Lemme show you something!!
Re: ELECTRICAL Question
Ok. Here's what I see. The wire you speak of appears to be too short. I would either replace it with a new wire that has a industrial grade ring terminal at the battery end and simply mount it on the clamp bolt. Then I would route it so that it enters the distribution block from the side (not the front). Clean up the post and use a new star lock washer and a nylock nut. That should take care of it.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
07-08-2008, 09:18 PM | #3 | |
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! Last edited by 70' GMC; 07-08-2008 at 10:31 PM. |
07-08-2008, 11:05 PM | #4 |
Here's what mine looks like......ain't never had a problem with it.
07-08-2008, 11:27 PM | #5 |
its all about the +6 inches
personally, I would measure the length of that whole cable, from the battery to the starter, and then the small wire too... add 4 inches to the measurement of the small one, and go buy a whole new cable. Those clamp on terminals are junk and will cause problems one day, and just gives it a rigged look.
07-09-2008, 10:12 AM | #6 |
what is this called it came loose from the wire.
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! |
07-09-2008, 10:48 AM | #7 |
ring terminal - goes on the end of the wire - most are crimped on - soldered would be better.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
07-09-2008, 12:15 PM | #8 |
Thanks for all the help guys.
07-09-2008, 03:54 PM | #9 | |
07-09-2008, 04:00 PM | #10 |
Fuseable link. make sure you replace it with a fuseable link. It should have had one there at one time and you can get them from your local auto parts dealer. It attaches to the terminal block and the other end to the red wire. easy install and great piece of mind.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. |
07-09-2008, 05:51 PM | #11 | |
07-09-2008, 08:57 PM | #12 |
does it matter anymore? Didn't this truck just get killed?
07-09-2008, 09:31 PM | #13 |
I guess it don't now But it did give em a blow out
