Old 07-09-2008, 01:37 AM   #1
SRH916
1975 C-10 Silverado LWB
SRH916's Avatar
Thumbs down Difference between C10 & C20 (1970)?
I am not sure if I undersand completely the differences between a C10 and C20. Can someone enlighten me on this? Please get down into the tiny little details if you can. I need to know as much as possible before going all in with a new old truck.
Thanks for the help,
Jared
1975 LWB C-10 Silverado
- Stock
- "BIG 10"
- 4 Bolt 350 "Brand new" 1200mi
- THM-375 "Brand new w/trans cooler" 5000mi
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
SRH916 is offline   Reply With Quote
Old 07-09-2008, 02:04 AM   #2
72lb4x4
Re: Difference between C10 & C20 (1970)?
Basically, its load carrying capacity. 10 is 1/2 ton (1000lb) and 20 is 3/4 ton (1500lb) (30 is 1 ton). Suspension parts are more heavy duty on the 3/4 and 1 ton than 1/2 ton. Frames in some cases (C30) can be beefier too I think.
3/4 and 1 tons will have larger tires and 8 lug wheels.
Cab mounts seem to be different but I'm no expert there. Just basing this from info in catalogs, since mines a 4x4 and they seem to share mounts with a 3/4 ton.
Shortbeds came only in a 1/2 ton version as far as I know, so if you want a shortbed, it may not be a good idea to get a C20 LWB and plan to shorten it.
Similarly, if you want to lower a truck it makes no sense (to me) to get a C20/C30.
72lb4x4 is offline   Reply With Quote
