Lowering A Leafspring 69 2wd Shortbed
Can Any One Tell How Many Leafs I Can Take Out To Lower It About 4-5 Inches Or The Best Way To Lower The Truck . I Have A Total Of 8 Leafs On My Leaf Springs
Re: Lowering A Leafspring 69 2wd Shortbed
Taking leaves out will let it settle down.To get that much guys do axle-flips where the axle gets moved over the leaves.There are other ways offered these days.There are spring mounts that locate the spring eyes higher up,leafs with an upward bend out of the eyes and little arch,and longer shackles.
I put a rear flip kit built by DJM Suspension from Godfather customs.
$127.00 Link to DJM http://www.djmsuspension.com/ Link to Godfather customs http://www.godfathercustoms.com/
Charles 1971 3/4 ton 454 cu.in. ![]() 4 speed manual 1966 Thunderbird 390 cu.in. Airride Roadster Last edited by Charlesdur; 07-09-2008 at 09:57 AM. |
Active Member
![]() Join Date: Jul 2007
I removed the lower three on my 68 GMC and it lowered it about 2 inches. Now, I'm going to get some lowering shackles for another 2 inches.
I didn't want to notch the frame by doing a flip kit. If I didn't do the notch, the frame would be about 1/2 to 1 inch from the rubber stop. A search on leaf springs will give you some good infor... |
![]() Join Date: Aug 2001
Just go to Early Classic Enterprise they will all what you need.
http://www.earlyclassic.com/
DREW67 |
I agree with SLVESSELS go with early classic. Thats where I bought my 4" drop springs. And 2.5" spindals with no problems.
Does Anybody Else Have 8 Leas In Ther Leaf Springs And Is My Truck A Heavy Duty Because I Seen Some Stock Tucks With About 5 Or 6 Leafs
Nothing to see here.....
![]() Join Date: Jun 2007
do you have a 3/4 ton? I haven't seen many 8 leaf 1/2 tonners......
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
Active Member
My 68 GMC shortbed came with 8. The guy I bought it from told me that his dad ordered it with heavy duty springs because it was a farm truck. He used to haul feed sacks with it for his cattle. According to him, they used to load it up with 50lbs sacks even with the top of the cab... I don't think I'll be doing that...
The shortest one is on top on this pic. |
learn something new everyday! thanks for posting the pic 68gmsee!
Active Member
It is sort of different. If you notice I don't have the square U bolts. Took the pic while I was trying to figure out how many leaves to take out.
I decided on the bottom three and left the short one on top as a spacer. It still seems a little bouncy on dirt roads (crappy shocks) but not bad on the highway. |
Has Any Body Lowerd A 8 Leaf Spring Truck And How Many Leafs Did U Take Out Or What Did You Do To Lower It
#13 |
SLVESSELS,
I think you could take 2 or 3 out, which would put you down a bit, but probably not much. Like several have said above, if you want a noticealble drop, you will more than likely need to pick up a flip kit. A well engineered flip kit will allow you to retain a smooth ride and "some" carrying capacity. just my .02. but what do I know, I have coils.....
#14 |
I Think If I Get A 2"drop Shackle And Take Abou 3 Leafs Out I Should Get About 3-4 Inchs
#15 |
can't hurt to give it a whirl! please post back on the results as it could be informative to others with leaf spring rears.
#16 |
Official Site Guitar Shredder
although i did a DJM Flip Kit as well.......subscribed..........Please post how this turns out...........
#17 |
I am interested in how it turns out, too.
![]() ![]() 1972 C20 Custom Deluxe: Rebuilt 402 hopped up a bit, th400 with shift kit, Dana 60(wanna have posi), New solid, no cancer, cab. B & M Starshifter floor shifter. ![]() |
#18 |
If you want 4" of drop you can install a drop shackles and hangers is cheap and easy and in the front you can install a drop coil springs... If you want more than 4" you can install a flip kit
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
#19 |
My truck has a HD suspension with 8 leafs I removed 2 leafs and dearched de longest... now I have 3" of drop.. I will install a drop shackles to obtain 2" more
#20 |
Active Member
On my post above, I mentioned I took three out. It dropped it about 2 inches. I'm also going with the lowering shackles to give me a couple of more inches. I'm not going to be using it for hauling but I'm going to hold on to the the extra leaves just in case.
#21 |
So Can Any Body Tell Me The Best Way To Remove The Leafs Fome The Leaf Springs And The Cheapest Place To Buy 2"drop Shackes
#22 | |
1972 c-20, 350/350, dana 60 w/456 gears(no Posi) Last edited by TotalChevy1; 07-11-2008 at 06:14 PM. |
#23 |
Active Member
On mine it wasn't that easy. If you're going to remove the whole spring asm, raise the truck to remove the tension off them.
I did one side at a time. I removed the lower bolt on my shock then removed the u-bolts, the nut on the center bolt that holds them together and removed the shackle bolts and nuts (that was a pain). I used a big c-clamp on the front and the back of the springs to hold them together and raised the truck higher to remove the complete asm. The second time I did it, I didn't remove the shackles. Did one side at a time. 1. I removed the u-bolts, center bolt nut, lower shock bolt, used the c-clamps on the top 5 leaves only so they would shift on me. 2. Raised the frame up until the springs came off the axle mount. 3. removed the 3 lower springs. |
#24 | |
Does that mean that thepeople with the 2" DJM drop shackles had to clearance the bed to use them? Sorry for the hijack Last edited by Baresteel10; 07-11-2008 at 07:46 PM. |
#25 |
In my case yes. I have a wood bed, so that may make a difference. I ended up shaving the bottom of the bed and here in the next couple months I'm taking the bed off to do some other work and my plan is to grind off about 1/4 in off the edge that is closes to the bed
1972 c-20, 350/350, dana 60 w/456 gears(no Posi) Last edited by TotalChevy1; 07-12-2008 at 12:40 AM. |
