rear ends- what years are a bolt in?
Hello all
this is my first post. I just picked up a 67 gmc stepside project. its for my stepson and is going to be a father/son project. it is obvious to me someone has put another rear in the truck since both factory shock mounts on the truck are forward of the rear and the rear in it now has staggerd shocks. someone just drilled a hole in the frame to mount the rear facing shock. My question is what years will just drop in? it is the factory leaf spring set up. Here is a pic of her. Thanks in advance. |
Re: rear ends- what years are a bolt in?
67-72 should bolt up with out making adjustments to the shock mounts or spring perches.
1969 red k/10 with sb350 4.11 gear ratio, front disk, 3 speed automatic |
if your sure it has been changed, the best thing to do is to take a pic and post it on here, so we can determine for sure
Travis
travis_moffatt@hotmail.com ![]() 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
Just about any GM leaf spring 6 lug rear will bolt up. maybe little mods. to brake lines and ebrake cables but other than that bolt right in.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
member #16
![]() Join Date: Dec 1999
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
laying low
![]() Join Date: Mar 2001
Yeah Missip'. Welcome to the Chevy truck hot spot.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
