Old 07-09-2008, 01:04 PM   #1
elektrik
Foolish Mortal
elektrik's Avatar
truck starting fine yesterday-now, nothing
Hi guys. Moved from TX to CA and had my truck transported and then stored for the past week at my pop's house with the battery disconnected. We connected it back up 2 days ago and it's been starting "ok" (more on this in a sec) and then this morning, nothing. it's like the battery's dead.
Ok, so when I say it's been starting "ok" I mean that it cranks most of the time, with a seemingly more frequent "clicking" where I'd turn the ignition and the truck would click. I'd have to repeat this several times in some cases until it cranked and the truck would start.
Anyone have any suggestions? Bad Battery? Starter?
elektrik is offline   Reply With Quote
Old 07-09-2008, 01:08 PM   #2
Brad
Out of the carpool lane.
Brad's Avatar
Re: truck starting fine yesterday-now, nothing
Sounds like the starter solenoid going out. You can replace it or, there's a copper disc inside it that wears out and gets pitted just like a points distributor. Flip that copper disc over and it should start right up.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 07-09-2008, 02:10 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I think I would agree with Brad but also take "all" (meaning both ends, big and small" of the battery cables off and clean the cables, bolts, washers, and nuts and re-assemble.
LockDoc
Leon
Old 07-09-2008, 03:05 PM   #4
70rs/ss
70rs/ss's Avatar
Check the voltage as well, the clicking can happen when the Batt is below the 12-14v.
70rs/ss is offline   Reply With Quote
Old 07-09-2008, 04:00 PM   #5
sickchevy68cst
Rice Killing 101
should still get a spinning of the selenoid at 12v i get it at 12.08 id say its the selenoid do wat he said
distrubin the peace since i got the thing and broke the origianl radio on 95.5 classic rock
Ride:
1968 c20 lwb 327(orig motor)/np435/eaton 4.10 w/posi
puttin in a 496 rebuilding trans need to rebuild diff :|
need to start takin pics and start a project thread
sickchevy68cst is offline   Reply With Quote
Old 07-09-2008, 04:41 PM   #6
lks dcvn
lks dcvn's Avatar
agree with 70rs/ss - take the battery to a garage (not Autozone) and ask them to put it on a charger and load test it - it will only take an hour or so...
My Impala and my trucks have done this before - battery just got too low and the starter would click - but wouldn't turn over...enough battery for lights, wipers, etc. - but just not enough juice for it to catch.
lks dcvn is offline   Reply With Quote
Old 07-09-2008, 09:05 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you tried jump starting it?
Old 07-25-2008, 10:53 PM   #8
elektrik
Foolish Mortal
elektrik's Avatar
I did. It turned out (At least I thought at the time) that the battery was dead. I purchased a battery, thinking that it was the problem (it had a car battery with ~500 cranking amps). But now the new heavier duty battery is dead, so I'm gonna try replacing the alternator and voltage regulator.....other than that, I'm gonna have to take it to a mechanic ( I hope not)...
Any easy "do-it-yourself" suggestions?
Old 07-25-2008, 11:00 PM   #9
Jcentsr6
Junior Member
Jcentsr6's Avatar
Make sure your truck is in Park...I know it sounds stupid but.....its happend before.
going to sell this one...looking for a SWB project next.
Jcentsr6 is offline   Reply With Quote
Old 07-25-2008, 11:47 PM   #10
463
463's Avatar
http://www.madelectrical.com/electrical-tech.shtml http://www.chevelles.com/techref/tecref14.html here is a good solution for the truck. did this on my 72 1/2 ton and should have did it years ago. http://67-72chevytrucks.com/vboard/s...=119379&page=2
Trueman
463 is offline   Reply With Quote
Old 07-28-2008, 10:35 PM   #11
elektrik
Foolish Mortal
elektrik's Avatar
So it turns out I've been in "freak out" mode so long I've overreacted once again (4 years of being "creative" in my finances from school); it was the alternator (and I changed the regulator too) to the grand total of $80 in parts.....
Thanks all for humoring me
