Old 07-09-2008, 03:13 PM   #1
umwtnt
umwtnt's Avatar
Body mount bolt torque
Hey guys, does anyone know if there is a factory torque for the radiator support and body bolts and, what are they? I am closed to installing my cab back on the frame and check alignment again but figure if there is a torque value that would help me out a lot. Thanks in advance.
umwtnt is offline   Reply With Quote
Old 07-09-2008, 09:09 PM   #2
JimKshortstep4x4
Re: Body mount bolt torque
Per the Shop Manual, the torque values are: Radiator supports 20 lb/ft
Front cab mounts 50 lb/ft
Rear cab mounts 20 lb/ft
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-10-2008, 01:58 PM   #3
umwtnt
umwtnt's Avatar
Thank you, thoses readings are much lower than I anticipated and I have tighten them to much in the past. This info helps me a lot, Thank you.
