Old 07-09-2008, 11:14 PM   #1
87 dually burb
my short bus
87 dually burb's Avatar
bagging a square body dually burb
little back ground 87 3/4ton 454/400
flipped in rear with 3" blocks (pulled over load leaf)
pulled springs and bump stops in front
still have to add 3" djm spindle
pic of rear before blocks added
front no springs or bump stops 2" to innerfender well
only full pic I have rite now will be on wheels tomorrow
what kind of lift can I get from a bag in the front running 3" spindles
going to add 1" bump stop for it to sit on when airred out in front
rear I want a bag over axle setup same ? what lift can I get with it
same 1" bump stop to rest when airred out
never bagged or dropped a truck this low my biggest issue is I want a good ride and plan to make many trips up and down the east coast with it
want a cheap but reliable set up for now just want to "t" the air line and run them to rear so a full air kit it out the pic for now just want bags and brackets and cups I guess
have 2 40lb co2 bottle for later use
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 07-10-2008, 12:45 AM   #2
Twistedsteel
Twistedsteel's Avatar
Re: bagging a square body dually burb
I've never seen one of those. Is that factory?
Twistedsteel is offline   Reply With Quote
Old 07-10-2008, 07:25 AM   #3
scotts62
One day...
scotts62's Avatar
WOW, thats different.. I like it!!
Scott
93 crew cab build
Project 62
Old 07-10-2008, 09:57 PM   #4
87 dually burb
my short bus
here it back on the ground for now added blocks and centered axle in well
thinking of cutting out the bracket the front bump stops were mounted on but they have the steering stop on it could get 1.5" more drop in front with a 1" bump stop in place for when it is airred down
Old 07-11-2008, 12:46 AM   #5
GMBowtie79
Surviving, one day at a time!
GMBowtie79's Avatar
Mines not a dually, I also didn't bag it (yet). Right now I'm running 3" drop spindles 1" drop coils with 1 coil cut off in front and a 6" flip in the back. any lower in the front and it starts hittin the control arms on uneven roads. As it sits right now I don't have any problems driving down the road. I don't like speed bumps they can be a problem. I like the dually Burbs I have seen 2 of them around here over the years that where dropped I think they look *****in good luck with yours.
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver
74 swb,350,350,driver & future project
"There's no such thing as a finished project"
GMBowtie79 is offline   Reply With Quote
Old 07-11-2008, 07:48 PM   #6
87 dually burb
my short bus
how tall is your front/rear tires??
my 235/85/16"s are tall but havent measured them yet
may change them out later
Old 07-11-2008, 07:59 PM   #7
GMBowtie79
GMBowtie79's Avatar
The front are 245-40-20 @ 28" and the rear are 265-50-20 @ 30".
Old 07-12-2008, 01:24 AM   #8
Mkcustums
Mkcustums's Avatar
Inspirational pics....
Mkcustums is offline   Reply With Quote
Old 07-12-2008, 09:41 AM   #9
SBTork
Garage wrench
SBTork's Avatar
Very cool dually 'burb with the cowl hood.
Good luck on the project, it looks like it's coming along good, and should be awesome when done.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 07-12-2008, 03:08 PM   #10
87 dually burb
my short bus
nice I ve been also lookin at a cowl hood but only a 2" or to keep it legal
