Never enough time!!
400SB balance plate??
Anyone have any experience with one? Would like to put the 400 I have in a truck with a manual transmission, I have a flywheel and clutch assembly that are good...NAPA lists a balance plate made by Zoom for use with an unweighted flywheel (NAPA part #NNC 624001)....just wondering if anyone had used one before. Thanks in advance for any input...Gord
Re: 400SB balance plate??
I have not used one but I did look at them before buying the correct flywheel. I was concerned about the extra part which is not part of the flywheel. I bought a flywheel from Northern Auto parts which has the weight cast into it.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
I've used one. I had a 79 K-10 with a granny 4 speed, changed the 350SB to a 400SB and used the balance plate with my orignal flywheel and clutch. Worked like a charm for me. No vibrations and the engine lasted until I sold it, maybe 20k later.
Randy, West TN 67 Fleetside SWB L6 3 speed on column 84 Feetside SWB L6 3 speed on column yes, I like column shifts 99 Dodge 4X4 Ext. Cab |
