Old 07-10-2008, 11:52 AM   #1
manimal
manimal's Avatar
A/C brackets for 6cyl
I am thinking about installing a 292 inplace of the 350 in my truck, but this thing has add-on A/C and I would like to keep it. Anyone know where toget the right brackets? Thanks
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-10-2008, 12:07 PM   #2
D13
D13's Avatar
Re: A/C brackets for 6cyl
A/C was available as an option on the L-6. Ebay occasionally will have bracket sets. The integral head long compressor ones are somewhat common, I've only seen 1 set for 292's in the last year.
It takes aonther groove in the crank pulley and water pump pulley, especially if you have Power Steering.
If your 292 is non-integral head, you may be best off fabricating your own brackets, since the 250 brackets aren't long enough.
If your compressor is non-GM (like a Sandeen) then you'll need custom brakets anyway as I haven't found a bolt-on bracket set. The compressor goes on the RH up high, the bracket bolts to the head and to the bolck at the accessory bolts jsut bhind the timing cover.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 07-11-2008, 05:56 AM   #3
D13
D13's Avatar
There's a 250 on Ebay that has aftermarket AC pump set up on it. You can see some of how the brackets are hung in the pictures. This won't bolt onto a 292 directly but you can get the idea.. the hardest part of fabbing these brackets is getting the pulley positioned front to back and square to the crank.
http://cgi.ebay.com/ebaymotors/1969-...spagenameZWDVW
1987 2 ton
