Old 07-11-2008, 08:47 AM   #1
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
rearend diff. anyone running a spool?
i just recently have grown the intrest to make my both back tires spin but the posis that i see are so much and i know that they help on a car that your going to be turning with but are there any of you out there that have tried running a spool instead of a differential, i was looking them up and they are only about 150 opposed to having to spend about 500 on an auburn diff.
staggerd86c-10 is offline   Reply With Quote
Old 07-11-2008, 09:01 AM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: rearend diff. anyone running a spool?
got a buddy who runs one and it does just fine, I wouldnt recomend it on a daily driver but on a weekend cruiser I'd so go for it. That's what I'm going to do with my 77 K5
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-11-2008, 09:15 AM   #3
85 c-10
I run one. I bought an axle kit from Moser and it came with it. I don't drive the truck that much, and I don't think it hurts anything, but I really don't like the sound of scrubbing tires everytime I turn.
josh
85 c-10 is offline   Reply With Quote
Old 07-11-2008, 09:28 AM   #4
swb85
On a budget like Fred Sanford
swb85's Avatar
You can run a spool on the street, but upgraded axles are a good idea as they see a lot of twisting stress around corners. Have to be real careful in the rain too.
Have you looked into the powertrax lockers? I run one in my truck and they're only $300, they install with no special tools and you don't even have to pull the carrier out (no gear setup). I beat the crap out of mine with 450+hp and a 4 speed.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 07-11-2008, 09:58 AM   #5
azfab
azfab's Avatar
dude you wont like it. weres out tirs so fast its mad for dirt and drag. i use on on the race car but not for the street. if you had to make a sharp turn the rear will push the front tires forward even if you had it maxed out.youll still tur but not well at all. if you rive it in the rain fish out of the water. youll be all over the rad if you beak trac. there fun but not they way to go, summit had cheap posis or look for a wrecked fwd they have them. sorry for the bad news lol
lifes short fabricate as much as you can!
azfab is offline   Reply With Quote
Old 07-11-2008, 10:41 AM   #6
staggerd86c-10
300 isnt too bad the ones i have seen range from 450 to 500 thats why i was trying to take a cheaper way out where did you get it so cheap jegs? also what rear is it that the truck came with 28 or 30 spline? everything was stock on the truck when i bought it and i know it was a pain in the a$$ when i bought the gears for the rear end.
Old 07-11-2008, 12:13 PM   #7
swb85
swb85's Avatar
This is what you'd need: (28 splines btw)
http://store.summitracing.com/partde...5&autoview=sku
Hell they're $20 cheaper now than when I bought mine 6 months ago!!!
